Pages: 1 2 [3]  All   Go Down
Author Topic: Little bit of a hole......  (Read 12050 times)
Re: Little bit of a hole......
« Reply #30 on: 12 May 2020, 17:25:17 »
Hopefully they'll be doing a full alignment to OOF spec, rather than the tracking...  :D
MikeDundee
  • Costa Del Peckham
« Reply #31 on: 12 May 2020, 18:56:33 »
I will be checking :y , personally when the bloke showed me their alignment was not a proper full set up, like I have seen elsewhere, unless i missed something, still need to go to specsavers ;D
MikeDundee
  • Costa Del Peckham
« Reply #32 on: 13 May 2020, 17:53:54 »
Well got the car back this afternoon job done not exactly perfect but done a reasonable job :y.......all in including rear track rods fitted £250........took the car to Mad House Tyre got the tracking done, gave them the settings, see results below, not exactly there but nearly.....
Tracking.....
« Reply #33 on: 13 May 2020, 17:56:44 »
Arse end looks fine :y
That front camber needs re doing, because they clearly didn't even try :-X
« Last Edit: 13 May 2020, 17:59:17 by Doctor Gollum »
MikeDundee
  • Costa Del Peckham
« Reply #34 on: 13 May 2020, 18:18:59 »
He said that was the best he could get it :o
« Reply #35 on: 13 May 2020, 18:27:39 »
Bollix.
They didn't even undo the nuts.
That's to say, the numbers are unchanged from the 'before' list so clearly they're talking Bollix, not you ;)
« Last Edit: 13 May 2020, 18:29:59 by Doctor Gollum »
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #36 on: 14 May 2020, 10:53:37 »
rubbish. There's easily 6° of adjustment just by loosening the strut to hub nuts and prying on the wheel.
Those figures of 1°28 will wear the inner tyre edges and make the steering really nervous. It should be more like 1°10.
MikeDundee
  • Costa Del Peckham
« Reply #37 on: 15 May 2020, 07:14:43 »
Cheers for the feedback, will be going round there this morning, get it sorted :y
Pages: 1 2 [3]  All   Go Up
