Author Topic: Random misfire fuel pump/injection relay  (Read 7736 times)
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« on: 09 May 2020, 13:53:19 »
Anybody know if the corsa fuel pump / injection relay will fit 3.2 mv6.    Their the same colour  ;D ;D car is playing up struggling to start and random misfire when going along.
Laying a rubber road.
Re: Random misfire fuel pump/injection relay
« Reply #1 on: 09 May 2020, 13:59:26 »
It could be that one of your dis packs has caught the corona virus Rae!   :D
Or that they're drowning in oil 'cos your cam cover gaskets are leaking...  :(
Raeturbo
  • South Wales
« Reply #2 on: 09 May 2020, 14:03:25 »
No oil there Steve, James done em👍 Dis packs are only a year old too, I suspect fuel problem the way it’s acting it’s more of a stumble than a definitive misfire
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #3 on: 09 May 2020, 14:13:15 »
Blocked fuel filter possibly, relay either works or doesn't so wouldnt suspect that, if in doubt bridge it feed the pump continuous to see if it helps
other rides
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #4 on: 09 May 2020, 14:13:36 »
Check if the numbers on top of the relay match, or just plug it in and see what happens.
Raeturbo
  • South Wales
« Reply #5 on: 09 May 2020, 14:14:26 »
                I’ll try it what numbers do I bridge
henryd
  • west cornwall
« Reply #6 on: 09 May 2020, 14:15:35 »
Not a clue ::) with out seeing wiring diagram :y
other rides
« Reply #7 on: 09 May 2020, 14:18:50 »
That's good.  :y  I hated changing cam cover gaskets!   ::)
Raeturbo
  • South Wales
« Reply #8 on: 09 May 2020, 14:43:15 »
Think it’s 30 and 87 going out to try now👀
« Reply #9 on: 09 May 2020, 14:46:37 »
Check codes and report back.
Use pedal trick if you have two working feet ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #10 on: 09 May 2020, 15:12:00 »
Relay is almost certainly the same.
It won't cause a misfire though.
Check the entire ignition system first, then the intake for air leaks. If those are all OK, measure the fuel pressure. THEN you start on the injectors and their wiring.
Raeturbo
  • South Wales
« Reply #11 on: 09 May 2020, 15:38:47 »
Tried the corsa relays they don’t work they are different. Bridged original relays no difference put it back to normal took it for a spin and it’s flying and tick over is perfect. Wonder if I’ve moved something around when I was fu(ing about with it and now it’s ok again, doubt it will last though. Running terrible on LPG then when I switch back on petrol it terrible too but switch it off start again and it’s ok, I have a two second flash on the lpg light which I will investigate. As for the pedal trick what do I do for that then? MV6 3.2. 2003
« Reply #12 on: 09 May 2020, 15:51:32 »
Really? There's a guide ::)
Raeturbo
  • South Wales
« Reply #13 on: 09 May 2020, 16:40:31 »
Ok I’ll search it now :y
Raeturbo
  • South Wales
« Reply #14 on: 09 May 2020, 17:49:44 »
Right done 10-6-5-10
