Pages: 1 ... 3 4 5 6 7 8 9 [10]   Go Down
Author Topic: Vectra 1.8 starter will not turn  (Read 41378 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Vectra 1.8 starter will not turn
« Reply #135 on: 27 May 2020, 08:10:08 »
It is pretty much impossible to put a system in place that detects loss of a ground connection and reports a trouble code associated with it  :y
Thank you. That leads me to wonder whether, had I got a man in to sort this car out, as suggested by DG and STEMO, he would have fared any better. I imagined that a Vauxhall dealer 'expert', with a superior diagnostic device, could simply plug it in and read out the fault.
« Reply #136 on: 27 May 2020, 09:21:08 »
Ah yes, a common misconception.
There is no diag kit on the planet that can tell you what the fault is, it can only tell you the symptoms  :y
It requires a level of care and thought to analyse the symptoms, carry out checks and determine the fault.....
.......and there in lies the problem, mechanics have little understanding of the systems and hence, if its not been seen before or is obvious........willy nilly part changing occurs and the bills sky rocket.
Pages: 1 ... 3 4 5 6 7 8 9 [10]   Go Up
