Author Topic: X30XE, getting a manual box to fit? Clutch question and lsd diff question  (Read 8740 times)
The Frod doesn't have them, which softens the rear end slightly cornering at speed... Makes it easier to gauge when you're getting towards the limit, where as the Omega relies on decent tyres to give you the same on limit performance. Of course, unless you actually drive the car properly, it's all a moot point and leaf springs and wooden wheels are fine ;D
« Last Edit: 10 June 2020, 14:04:28 by Doctor Gollum »
  • Chatham, Kent
    • Ghastly 1.0l Focus
I suspect that this is predominantly down to the rear track rods resisting the trailing arm loads across the car under load...
you think a 12mm rod with rubber bushes on each end can do that effectively ;D The most it's doing is preloading the trailing arm bushes to provide toe or camber.....
Properly setup leaf springs are extremely effective, although getting a good ride to go with the handling can be tricky.
« Last Edit: 10 June 2020, 16:14:37 by Nick W »
It's about the only difference between the Frod trailing arm rear end and the Omega one, so they must do something :-\
Mind you, given your soft spot for the Crapi, if anyone knows how to set up a cart spring, it's probably you :y
  • Chatham, Kent
Ford keep the entire rear suspension, including the diff mount in the rear subframe. Different geometry would easily make the difference; just look at the difference adding 20 minutes of camber makes to the Omega, which isn't possible on a Granada.
Making a Capri rear work is easy: new springs, shocks and bushes then ensure the axle is centered and square in the car using a tape measure.
That last sentence being the bit they skipped at the factory then :D
