Thinking of fitting DRL.......thought's/advice needed
Started by dave.h, 18 May 2020, 23:54:48
Quote from: Entwood on 20 May 2020, 22:21:56
Just a quick thought to those fitting DIY DRL's .... have you ensured they either dim when headlights are switched on or go off at that point ???
AFAIK it is illegal for them to remain on at full brightness  (as dangerous due to blinding others)...
You've not really read the original question have Nige?  ::) ::)
annihilator
Quoteillegal for them to remain on at full brightness
Plenty of options on ebay
https://www.ebay.co.uk/itm/202673860226
dave the builder
"You only need to inspect daytime running lamps (DRLs) if they're fitted as original equipment to vehicles first used on or after 1 March 2018."
from the MOT manual
https://www.gov.uk/guidance/mot-inspection-manual-for-private-passenger-and-light-commercial-vehicles/4-lamps-reflectors-and-electrical-equipment#section-4-1-4
Though appropriate switching is sensible if you do retro fit
personally ,I don't see the point of them  ;D
Quote from: Andy B on 20 May 2020, 22:29:04
Yup I had .. OP knows the law/courtesy to others/common sense ... others posting after with their ideas may not ....
Quote from: dave the builder on 21 May 2020, 09:22:12.......
Likewise ....
my Smart has them as standard but I always drive with my lights on
My ML has them too (though they have the option to be turned off) but if you can't see an ML .....  ::)
Quote from: Entwood on 20 May 2020, 22:21:56....
And then there are the road users that are too stupid to turn their lights on when it's dark which means their fully lit DRLs are blindingly bright!  >:( >:(
Quote from: Andy B on 21 May 2020, 16:19:57
.... and being so stupid don't realise that on most vehicles it means they have no lights at the rear at all ....
annihilator
Pipe and slippers brigade in fine voice on this post  ;D
Quote from: Entwood on 21 May 2020, 16:39:48
This does add a certain je ne sais quoi to motorway driving in poor weather, although you know that they'll be sat in lane 2, so you can pre-empt them to a degree ::)
amba
I fitted a set of Phillips DRL lights around 2 years ago as I was fed up with other cars just pulling out or clearly making little attempt to check for other cars before doing so.
I was concerned they would look stupid or even make the front of the car look unbalanced given the low fog lights on the front.The set I bought werent cheap but I anted something that worked properly and was fit for purpose.These are wired from a main unit that is connected into the side light buld wiring and when the ignition is turned on and car started they are illuminated.When you turn either side or full lights on they are extinguished so comply with the law as it stands.
The car has passed 2 MOT,s since being fitted with no comments from tester.My own view is they are a good idea and do give a very clear light even in bright sunshine and make the car much more visible for other road users without it looking like a christmas tree or a pimped up limo.
TBH I am glad that I fitted them and am sure they have gone a long way to making my presence on the road better so surely that is the purpose of them.As said they were far from cheap but have worked without fault for in excess of 2 years.
Pity I cant post pictures or I would be happy to do so ,but my IT skills dont extend to that
As the problem is caused by people pull out without looking... How an earth does fitting more lights solve anything ::)
dave the builder
Indeed , if you can't see 2 ton of steel the size of a ....erm ...... car  ;D without added fairy lights ,you probably shouldn't be driving
amba
Surprisingly the added "Fairy Lights" does seem to make other road users notice more .As said just MHO
Most of them do notice, but pull out anyway. Happened to me this morning, a white transit saw me coming but pulled out in front of me. I floored it straight past him and pulled in sharpish with smoke coming out of my ears. The temptation to slam on was overwhelming, but I noticed two large workmen sitting in the front so immediately calmed down.  ;D
dave the builder
Quote from: amba on 21 May 2020, 19:36:45
If it works for you ,and avoids accidents with blind people fairy nuff  :y
some Battenburg or reflective police livery chevrons I do notice  ;D  :P
and the flashing blue lights  :o
