Author Topic: Antifreez coolant question  (Read 7894 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« on: 24 May 2020, 19:35:25 »
Family cars at the moment are all petrol.
Fiat Seicento 1.1 2002, Omega 2003 2.2, Audi A4 2.0T FSI 2005, Nissan Note 1.6 2006 and a Honda 2009.
Is there one antifreeze/coolant that I can use for all the cars?
I normally go with a 20l container of the GM.
I've noticed that a lot of them are g12 and g13. I've seen some G13 ready mix.
https://www.ebay.co.uk/itm/20L-MANNOL-AG13-GREEN-Antifreeze-Coolant-Concentrated-to-40-C-LONGLIFE-J1034/202822364966?epid=26015296874&hash=item2f3927af26:g:3V4AAOSwF3BesDy8
Re: Antifreez coolant question
« Reply #1 on: 24 May 2020, 19:45:10 »
I wouldn't have thought it made much difference which one you use as long as you flush out what ever is already in the system & don't mix it
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #2 on: 24 May 2020, 21:30:16 »
The trouble with older cars unless you know their history is that you're depending on them having in what they're supposed to have.There are as far as I know three types 1 Non-OAT that's the ethylene glycol[usually blue] 2 OAT and 3 HOAT you certainly can't mix 1 with 2 or 3,whether you can mix 2 and 3 I don't know and how you tell what's in there already I don't know either.As Andy B says your best bet is to really flush the entire system and then refill with whichever you want.
« Reply #3 on: 24 May 2020, 22:15:21 »
Not so fast...
They're designed to work with different engine materials, so using an inappropriate coolant for engine material could end in tears.
'Waterless' coolant may be the way forward but it's relatively expensive, and you'll still need to confirm compatibility.
That said, it could be a genuine one for all solution  :y
Keith ABS
  • Maldon Essex
« Reply #4 on: 25 May 2020, 07:38:39 »
 I have been hearing that the waterless coolant does not bode well with aluminium head engines
Rangie
  • Lincolnshire
    • RRS TDV8 Yaris Cross
« Reply #5 on: 25 May 2020, 07:47:08 »
Drain & check the manual simple.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #6 on: 25 May 2020, 07:57:23 »
The only fly in that lot is the Audi, the rest will quite happily use red GM, check Manual, and act accordingly,,
Hoof'land storeman.
ronnyd
  • Online Online
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #7 on: 25 May 2020, 15:51:20 »
Quite correct, but doesn,t help the OPs original question as to using same for all his marques.  :-\
Rangie
  • Lincolnshire
« Reply #8 on: 25 May 2020, 16:19:40 »
Then check all the manuals.
ronnyd
  • Online Online
« Reply #9 on: 25 May 2020, 16:27:15 »
Thought that's what you meant.  ;D
Rangie
  • Lincolnshire
« Reply #10 on: 25 May 2020, 16:31:52 »
It's the easiest way, I've had to buy cold climate fluid for the RR something I'd never heard of before  it's far better to read the manual than rely on folk guessing , the cold climate is for the power steering & dynamic response resovoir.
« Last Edit: 25 May 2020, 16:44:41 by Rangie »
« Reply #11 on: 26 May 2020, 09:03:22 »
This, most manufacturers were onto OAT based coolant in the late 90s.
« Reply #12 on: 26 May 2020, 09:42:23 »
Who'd have thought that coolant could be so complicated ...... https://en.wikipedia.org/wiki/Antifreeze  :-\
Andy A
  • Bristol UK
« Reply #13 on: 03 June 2020, 10:24:48 »
I'm putting the GM in the fiat and keeping it in the Omega.
Audi coolant at the moment is up to G13 after from G12 to G12+, then G12++ and now G13. how confusing is that.
What's your thoughts on people calling Dex-Cool, Death-kill?
I took my old rad apart after reading about it to have a look the other day and found brown muddy slippery substance in the rad.  :o
Coolant changed every time the cam belt was every 4 years.
« Reply #14 on: 03 June 2020, 10:37:20 »
You can't undo what the previous owners did/didn't do ;)
Flush it a couple of times when you next change it  :y
