Pages: 1 [2] 3  All   Go Down
Author Topic: A few pics of the old bus.  (Read 95446 times)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: A few pics of the old bus.
« Reply #15 on: 26 May 2020, 13:35:00 »
Not a lot of weight in the boot tbh, but I can see what you mean. Will do a bit of investigation in the near future.
Migv6 le Frog Fan
« Reply #16 on: 26 May 2020, 14:43:03 »
Been thinking about this a bit more. There is a spare battery in the boot, the detachable towbar, and a few other sundry bits & pieces.
I suppose that adds up to a few kilos, but I still don't think it should be enough to make it sit down a bit at the rear.
The piece of road is quite flat by the way.
Rear shocks are a couple of weeks old and rear springs are about 3 years old. I inspected the springs and everything else at the rear when I fitted the dampers and everything appeared to be fine.
Next time I have it on a flat piece of road I will measure ride heights on all four corners and see whats what.
luizvivas
  • Belo Horizonte, MG, Brazil
  • 92/93 Toulon Green 1-5-3-6-2-4
    • Omega CD 3.0 Turbo
« Reply #17 on: 26 May 2020, 14:43:55 »
Was bored at work on a sunny day, so took a few more pics of the old girl.
What a beautiful machine !!!  :y :y :y
Powered by C30NE
Migv6 le Frog Fan
« Reply #18 on: 26 May 2020, 14:45:25 »
Thankyou very much Luiz.
    • 530D M Sport, 330i Coupe
« Reply #19 on: 26 May 2020, 14:51:07 »
It could just be my eyesight. Also I have three cars with three different setups so I can't really remember what standard ride height should look like!
amba
  • Medway towns
    • German V6
« Reply #20 on: 26 May 2020, 15:03:41 »
Visually that seems to sit about the same level as mine,which has 1 year old  Sachs rears shocks and springs, although mine has around 150kg of wooden samples in bags in the boot. :o
Might be worth having another look as you say as from memory the measurements from ground to centre of bottom of arch bodywork is around 665mm as std
« Reply #21 on: 26 May 2020, 16:46:01 »
670mm front and rear to centre of the wheel arch from memory  ;)
Migv6 le Frog Fan
« Reply #22 on: 26 May 2020, 17:25:03 »
Will check. Out of curiousity as much as anything else. I doubt theres anything seriously amiss, but you never know.  :y
amba
  • Medway towns
    • German V6
« Reply #23 on: 26 May 2020, 19:34:55 »
Im sure there isnt it just the pictures and "our critical viewing " of things.....scrubs up nicely well done Albs
Olympia5776
  • Ireland
« Reply #24 on: 28 May 2020, 13:30:39 »
Lovely, lovely car Albs ...nice to see another member on the OOF actually still has an Omega . ;D
Do you work in a crematorium ?
« Reply #25 on: 28 May 2020, 15:15:47 »
Albs wouldn't get that close to a crematorium, frighten the living shite out of him  ;D
« Reply #26 on: 28 May 2020, 17:43:19 »
Yep...great condition and a great colour.
I sometimes wonder if Mr Bitz actually does any work.....at work. ::)
Migv6 le Frog Fan
« Reply #27 on: 28 May 2020, 18:54:12 »
No, why ? ;D
I work here.
https://www.cmlmicroplc.com/contact-us/
Set in 27 acres of its own private parkland. A much nicer place to be than the concrete flooring works I spent the previous 20 years at, or the foundry I spent 9 years at before that.  :)
I spend a lot of time watching the badgers, muntjac deer, foxes, hares, pheasants and wabbits on the security monitors.
If there is ever a food shortage, I wont go hungry.  ;)
Migv6 le Frog Fan
« Reply #28 on: 28 May 2020, 18:57:05 »
No fear of the Crem here Steve. I could fall off my perch tomorrow and I couldnt give a toss tbh. It comes to us all at some point so why worry about it. Told the family when it happens, send my carcass to be burnt and then scatter it somewhere if you want to, but ffs dont waste money on a funeral. :)
Migv6 le Frog Fan
« Reply #29 on: 28 May 2020, 19:02:10 »
Very little tbh. I was told when offered the job " we need a presence, a bum in a chair". And I have been doing just that for 11 1/2 years now. Millions of pounds worth of gear here, and if no-one is on the premises it isnt insured so someone has to be here out of working hours 365 days of the year. The well equipped workshop has to be used. It would be rude not to.  :)
Suits me just fine at this stage in my life. In fact, Im hoping to keep doing it until Im 70, but we shall see. ;)
Pages: 1 [2] 3  All   Go Up
