O2 sensors
Started by tango, 27 May 2020, 03:47:07
tango
#15
Long story lol
I measured the reading between the two white wires and it was zero
So it was buggered
Now coming to removing that o2 sensor it wasn't budging
After fighting with it for ever lying under the car wasn't the best position to apply some torque
Drove to a local garage and they managed to take it off but the threads were destroyed as whoever put it on cross threaded it
I've ordered a lamda nut
Just waiting on that so can get it welded on and then hopefully put the Replacemnt sensor on
Not driving it now as it doesn't sound very good with a hole in the exhaust
Will report back in a few days hopefully
It probably wasn't cross-threaded, but just seized. It's a short, coarse thread(1.5mm) that probably only has about 3 threads engaged. It doesn't take much to ruin the threads when both parts are new ::)
Enceladus
#17
Quote from: tango on 02 June 2020, 02:55:24
Long story lol
So it was buggered
Isn't this the sensor that you replaced with a used spare you happened to have, that also proved to be faulty?
The sensors that were in Bank-2/Sensor-1?
Or is it some other sensor?
Or what?
tango
#18
Quote from: Enceladus on 02 June 2020, 11:57:34
Long story lol
So it was buggered
Or what?
no I replaced sensor 1 in bank 2 (luckily that came out nice )
As that was showing up faulty originally
After replacing that, sensor 2 in same back started showing up as faulty
tango
Quote from: Nick W on 02 June 2020, 09:43:45
probably was seized and your right it only locks on a few threads but a right mess when it came out
tango
I bought a taper tap 1.5mm m18 as this was recommended by the garage as a better solution
And luckily he was able re thread the existing nut
The sensor went in nicely and tightened
The fault has disappeared
So currently showing no faults
I only drove it a few miles back home but will see over the next few days how it goes
