iphone as satnav.
Started by Migv6 le Frog Fan, 30 May 2020, 18:33:36
Migv6 le Frog Fan
Ok done that. Sat in my front room trying to play with it but it says no GPS signal.  :-\ ::)
redelitev6
Stop when you get to the sea  :y
Migv6 le Frog Fan
Why, I likes the sea you see.  :)
It told me to go outdoors to get a GPS signal ,so I did but there was still no signal. Cant beat a good Atlas tucked in the back of the seat.  ::)
Quote from: Migv6 le Frog Fan on 30 May 2020, 21:26:50
do you have wifi or 4G /mobile data turned on?
Broomies Mate
Settings > Mobile Data > Slide the top setting On (to the right).
Quote from: Broomies Mate on 30 May 2020, 21:57:16
Sliiiiide to the right .... we know a song about that ...    :)
https://www.youtube.com/watch?v=wZv62ShoStY
Migv6 le Frog Fan
wifi and mobile data are on. Roaming is on (dont know of it should be ?) personal hotspot is off.
I suspect I may have had to go far enough from the house for it to lose the wifi signal and then data takes over ?  :-\
Mister Rog
Quote from: Migv6 le Frog Fan on 30 May 2020, 18:33:36
Wouldnt know where to start, but it could be useful tomorow morning if my sketch from google maps lets me down.
Any info, in very simple terms would be useful thanks.  :y
Otherwise I will use the Omega satnav as a backup but its quite a few years out of date. :)
Omegas had built in Sat Nav ? I never knew that.
"The desire to be a politician should bar you for life from ever becoming one." Billy Connolly
Or type the road name/post code in the search bar then press directions/take me there...
Or is that too easy/sensible :D
Migv6 le Frog Fan
Quote from: Mister Rog on 30 May 2020, 22:59:13
Elites did. :y
Migv6 le Frog Fan
Quote from: Doctor Gollum on 30 May 2020, 23:03:36
If I have a GPS signal it should be easy enough - I hope.  :D
Migv6 le Frog Fan
Used the old Omega satnav to get there without any problems, and used Waze on my phone on the way back also without problems.
ronnyd
Surely you didn't need a satnav to get back. :o ;)
Migv6 le Frog Fan
Not really no. Just thought I would test out Waze as I only downloaded it last night.  :y
henryd
Quote from: Broomies Mate on 30 May 2020, 18:34:54
Download 'Waze'.  Free and tells you where the naughty police officers are.
This ^^,its very good and free
other rides
