Author Topic: Low brake pad warning on Tata.  (Read 16459 times)
« on: 21 June 2020, 17:30:52 »
Presumably the warning is related to the front pads and not the rear. The car has covered 19600 miles. Looking through the wheels the pads appear to have 5-6mm of 'meat' left........the drivers side having slightly less.
Just ignore the warning or can I switch it off?
Re: Low brake pad warning on Tata.
« Reply #1 on: 21 June 2020, 17:33:53 »
What do the good people on the jag forum say? Just throw it away and buy a new one?  ;D
« Reply #2 on: 21 June 2020, 17:58:26 »
Get it trailered to your friendly Jag dealer pronto!  :y
« Reply #3 on: 21 June 2020, 17:59:51 »
I wouldn't want to be 'making progress' in that beast and suddenly run out of brake pedal.
« Reply #4 on: 21 June 2020, 18:02:08 »
There are sensors front and rear.  Like all sensors, there will be plenty of pad on, mores if the discs are lipped....
....*BUT* the less pad material thats left, the lower the cooling ability.  For that reason I tend to change mine before or when the sensor breaks.
Not ability to turn off the warning, but like most cars, you can short the sensors.
« Reply #5 on: 21 June 2020, 18:21:14 »
Take it to your local dealer is all they know. Lazy fat bastards.
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #6 on: 21 June 2020, 20:51:55 »
The bimmer used to use the rear pads for traction control, so they may well be more worn than you think, depending on your driving style.  8)
« Reply #7 on: 22 June 2020, 08:51:59 »
As does the (post 98) Omega
« Reply #8 on: 22 June 2020, 11:26:09 »
Not stability control, more vectoring to get the back to turn tighter corners  :y
« Reply #9 on: 22 June 2020, 13:12:32 »
It seems he prefers driving the rusty old Vauxhall....  :-\
« Reply #10 on: 22 June 2020, 17:46:34 »
Rear pads appear to have only 2-3 mm left so I'm guessing this is why the low pad warning light came on.
I'll price up new pads, discs all appear to be fine, with no 'lips'
« Reply #11 on: 22 June 2020, 18:30:20 »
I'm sure you'll find a 'How to..' guide in the maintenance section of the Jag forum.  :)
« Reply #12 on: 22 June 2020, 18:57:19 »
Although you might find that the caliper pistons are electronically wound in and you'll need JagTech (or whatever their system is called) for that.  :-\
« Reply #13 on: 22 June 2020, 19:01:47 »
Jaguar fixed pricing for cars 3 years and older.
Front pads £195......or £235 with new sensors,
Rear pads £159 ......or £235 with new sensors.
Presumably they can re-use the old sensors provided they are not 'Donald Ducked'
Are sensors even necessary?
« Reply #14 on: 22 June 2020, 19:14:16 »
Rear pads down to 2-3mm. Are sensors even necessary?  ::) ::)
Pages: [1] 2 3 4  All   Go Up
