Author Topic: Household electrickery question. Or two...  (Read 9979 times)
  • Online Online
Re: Household electrickery question. Or two...
« Reply #15 on: 09 July 2020, 19:06:12 »
My mate had a new combi boiler fitted in the attic and after about 6 months a push fit joint let go!  :o  You can imagine the mess!  ::)
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
« Reply #16 on: 09 July 2020, 19:17:45 »
.....and that is exactly the type of stories I have heard about the push fits and why I will never use them. ::) ::) :)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #17 on: 09 July 2020, 20:27:38 »
If you don't like push fit .......
use compression fittings and inserts with plastic pipe then  ;D
I still use Ye Olde copper on central heating systems and all gas (plus the use of Tracpipe ,which is plastic coated stainless steel )
BUT for water ,John Guest fittings are well made ,
leaks happen when people damage the O rings by NOT cutting the pipe cleanly ,or run boilers at stupid high temperatures
« Reply #18 on: 09 July 2020, 20:30:23 »
I had a radiator's feed & return pipework altered last year & the plumber used plastic  ??? ..... it was done by the time I came home from work. I'll get around to replacing it with copper ..... one day  ::)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19 on: 09 July 2020, 20:39:39 »
as long as there is 1 meter of copper pipe at the boiler manifold on the flow and return ,and you keep the central heating circulating at a sensible temp (70 degrees) all should be grand  :)
so don't turn your boiler up to "ELEVEN"  :o   ;D
  • Online Online
« Reply #20 on: 09 July 2020, 20:53:59 »
I had a radiator's feed & return pipework altered last year & the plumber used plastic  ??? ..... it was done by the time I came home from work. I'll get around to replacing it with copper ..... when it starts leaking!  ::)
FTFY Andy!  ;)
« Reply #21 on: 09 July 2020, 20:55:42 »
The radiator is probably as far from the boiler as you can get. The plastic is mostly hidden behind the couch but I know it's there & I'm not keen on the idea of plastic either  ;D
« Reply #22 on: 09 July 2020, 20:56:15 »
FTFY Andy!  ;)
Probably!  ;D ;D ;D
« Reply #23 on: 09 July 2020, 22:25:01 »
Instructions of our Vailant suggest not going past 4.5 as we're in a hard water area :'(
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #24 on: 10 July 2020, 12:21:18 »
the eleven I quoted was not a boiler setting ,it's from the film Spinal Tap ,
Nigel Tufnel proudly demonstrates the guitar amplifiers volume knobs are marked from zero to eleven, not just 10   :)
my Worcester Bosch only goes up to 6 ,but it's set at 4 ,
though Mrs Builder has the DHW (hot water) set to the "melt human flesh" setting quite often  ::)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #25 on: 10 July 2020, 14:42:23 »
yet it's much easier to screwup metal pipe and soldered joints......
« Reply #26 on: 10 July 2020, 21:03:26 »
I got the reference  ;)
No complaints re temp though, 38 is fine for a splash, and hotter for a soak :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #27 on: 11 July 2020, 13:37:20 »
Personally, I'm not qualified,
I'm not qualified either, but it didn't stop me from wiring all my lights in the home off the street light outside, it's brilliant all the lights come on when the sun goes down, downside is it all goes dark and gets switched off at 1 oclock in the morning.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #28 on: 11 July 2020, 14:40:39 »
;D ;D
Page created in 0.028 seconds with 20 queries.
