Author Topic: 3.2 Alternator removal/refit  (Read 6978 times)
« on: 14 July 2020, 13:28:38 »
So save getting lost in the other thread...
So using this (from an early v6) as a basis - http://www.omegaowners.com/forum/index.php?topic=107049.0
Implication is there is a bolt/nut at rear of alternator.  Is that still same for 3.2?
Re: 3.2 Alternator removal/refit
« Reply #1 on: 14 July 2020, 13:40:10 »
From memory yes as the block is fundamentally the same.
Can be done without jacking, but lifting the header tank may improve elbow room ;)
And yes wiring is traditional nut on stud :y
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #2 on: 14 July 2020, 14:16:20 »
Before removing it have a gander if it can be done on the car. I really dont remember removing the alternator when I changed the regulator.  :-\
456lbft
    • Omega MV6-Fred
« Reply #3 on: 14 July 2020, 14:36:36 »
Not too bad a job when the belts are being done.
Carlton 3.6 Track Car
Omega 3.2 MV6 Fred
« Reply #4 on: 14 July 2020, 20:32:13 »
I'd say you'd have no hope with it in the car. Not a bad job to get the alternator in/out but it's fiddly getting to the nuts on the back of the alternator. Couple of extension bars and some gadget hands required.
Migv6 le Frog Fan
« Reply #5 on: 14 July 2020, 21:47:43 »
Reply number 25 in the thread below confirms Kevin is corect, my memory is shot to bits, and I wastalking shite - again.  ::) ;D
http://www.omegaowners.com/forum/index.php?topic=144140.15
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #6 on: 15 July 2020, 11:18:04 »
Thinking back, I'm almost sure that this was the job where I glued/blue tacked the nut to my finger, as I was getting pissed off with the nut not quite sitting straight on the bolt thread when it was between my fingers. Worked a treat.  :y ;D
    • 530D M Sport, 330i Coupe
« Reply #7 on: 15 July 2020, 14:39:34 »
Yes I do remember one (top I think) being a bit of a fiddle to line up
« Reply #8 on: 15 July 2020, 19:24:59 »
The nut that holds the cable to a stud? Not a nut that the main mounting bolts use?
YZ250
« Reply #9 on: 15 July 2020, 19:51:51 »
I'm sure it was the mounting bolt nut as I went underneath to sort the wires. Also, if doing from above you can get the wires attached before fitting it properly. You are working by feel, not by sight. How soon are you going to be doing it, happy to pop over if I can help in any way.  :y
« Reply #10 on: 15 July 2020, 19:52:42 »
Those two are easy enough to remove once you have the Alternator free and can move it to get to them.
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #11 on: 15 July 2020, 20:46:11 »
There's enough slack on the cables to lay the alt face down to undo the electickery cables, bottom fixing bolt is a pain in the ass but securing the nut into a ring spanner with duct tape helps when refitting the alt massively
« Reply #12 on: 21 July 2020, 19:27:07 »
Job jobbed, many thanks to all those who have advice, esp that DTM chap, who had to tolerate some daft questions today.
He reckons 40 mins.  Took me over 2hrs ;D.  Next time would be quicker, obviously. Hope there isn't a next time though ;D
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #13 on: 22 July 2020, 12:09:56 »
It's an age thing 8)
I like red cars
« Reply #14 on: 22 July 2020, 17:51:04 »
Aye. And I am old. I can even join your Saga club now :P
