Author Topic: 2.6 lower sump gasket dilemma  (Read 3180 times)
mantamania
  • Chatham, Kent
    • 2.6 Elite
« on: 21 July 2020, 14:11:28 »
Hi all,
To cut a long story short, i have had intermittent low oil pressure and decided to remove the sump and clean the oil delivery tube. I went to local dealers to get oil, filter, "o" ring for delivery tube and sump gasket.  I was told that the lower sump uses a sealant as a gasket and it is expensive and advised me to get "Elring Dirko S HT" as it is the same stuff but cheaper.
On un-bolting the sump i discoverd that there is a rubber coated gasket and no sign of any sealant.  When i bought the car it came with full service history and all other work had been done at main dealers. I checked through everything and there was nothing about having the sump gasket replaced. This has lead to be believing the gasket was fitted from new.
My dilemma is do i use the sealant or the gasket?
Thanks
Mantamania
Re: 2.6 lower sump gasket dilemma
« Reply #1 on: 21 July 2020, 14:26:40 »
Gasket was initially used at the factory, but they later changed to sealant and gaskets no longer available, so both technically correct. :y
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #2 on: 21 July 2020, 15:33:12 »
I had the sump off mine to clean the strainer a few weeks ago. I used Hylomar blue sealnt when refitting it ans theres no sign of any leaks.   ;)
mantamania
  • Chatham, Kent
    • 2.6 Elite
« Reply #3 on: 05 August 2020, 14:54:30 »
Thanks for the advice, I decided to get an Elring gasket. I am glad I did as laying under the car I know that if I had used the proper sealant there was no way I would have been able to get the 20 bolts in and torqued up in the 10 minutes specified on the sealant.
« Reply #4 on: 05 August 2020, 15:57:08 »
How not ???
New POD
  • Miseryside
    • NEED MV6
« Reply #5 on: 07 August 2020, 08:51:59 »
How not ???
Not everyone is as talented as you imagine.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #6 on: 07 August 2020, 09:30:16 »
How not ???
apply the sealant, fit a bolt in each corner and wind them in a couple of threads so the cover 'hangs' from them. Add the remaining bolts, and tighten them with a ratchet and extension that you can spin. That's a couple of minutes if you take your time, and a small cordless impact driver will be even quicker.
While you're under there, spend a fiver on a new oil pressure sender.
« Reply #7 on: 07 August 2020, 10:37:38 »
How not ???
Having done the job, I know what's involved.
