Author Topic: Secondary fan sensor/switch  (Read 3384 times)
tooleater
  • Rickmansworth,  Herts
    • Go faster Black MV6 Man
« on: 22 July 2020, 15:32:22 »
Hi guys, can someone confirm is the connector wiring block to lower fan switch on rad, circular, I can only see the upper fan temperature sensor/switch which is rectangular, I've tested this and all fans are good, I just can't see the lower one as I want to replace both.
Re: Secondary fan sensor/switch
« Reply #1 on: 22 July 2020, 16:31:59 »
Three pin in a T shape iirc :y
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #2 on: 22 July 2020, 20:12:39 »
Upper one is rectangular-but can have either two or three connector pins o make sure you check which one you need.The lower one is circular with as DG says three connectors in a T shape pattern.
tooleater
« Reply #3 on: 23 July 2020, 12:27:44 »
Cheers guys, that's a big help, least now I know what to order for the secondary switch. apologies for late reply. Dickie stomach  :-[
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #4 on: 23 July 2020, 16:47:54 »
 Here's a handy photo :y
Hoof'land storeman.
