Self levelling headlight
Started by laney101, 24 July 2020, 10:26:12
omegod
I've a pair of working sensors at mine Dave if you want to try substitution
Sensors, adjusters, motors, wiring and headlight ecu are all possibilities.
If the first three don't work, then it's time to check it properly.
laney101
May indeed tske you up on thay cheers.
Gonna fix adjusters. See if that works
Then check wiring to sensors make sure i got voltshe to sensors.
If thats ok ill try your sensors then fella.
Past thay maybe module. I will get it sorted.
Quote from: omegod on 28 July 2020, 10:08:33
