Author Topic: Front hubs.  (Read 8170 times)
tooleater
  • Rickmansworth,  Herts
    • Go faster Black MV6 Man
Front hubs.
« on: 27 July 2020, 13:53:58 »
Hi guys is there anywhere I could purchase 2 over a counter before Thursday at reasonable cost with decent longevity, only cover approx 3k a year..
tooleater
Re: Front hubs.
« Reply #1 on: 27 July 2020, 13:58:38 »
Hi guys is there anywhere I could purchase 2 hubs over a counter before Thursday, at reasonable cost with decent longevity, only cover appox 3k a year.
Cheers  :y
Re: Front hubs.
« Reply #2 on: 27 July 2020, 17:13:17 »
Ebay or your nearest motor factors.
Although if you're only doing that mileage, are they bad enough to warrant changing?
Only ever changed front bearings on one Omega :-\
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Front hubs.
« Reply #3 on: 27 July 2020, 17:23:04 »
It's a bit odd having  to change both ???
danny21
  • eastbourne
    • omega2.2
Re: Front hubs.
« Reply #4 on: 27 July 2020, 18:43:15 »
I have 2 hubs of a 2.2 2002 model but it would be getting them to you as I live on the south coast
tooleater
Re: Front hubs.
« Reply #5 on: 27 July 2020, 19:00:15 »
. It's just me DG, prefer to change both. Mot was an advisory
tooleater
Re: Front hubs.
« Reply #6 on: 27 July 2020, 19:01:10 »
My IT skills are appalling  :-[
  • Chatham, Kent
Re: Front hubs.
« Reply #7 on: 27 July 2020, 19:12:31 »
Considering that most of these cars are scrapped with their original bearings, they're really only worth changing when they fail. If they were ordinary taper bearings it might be worth removing, cleaning and inspecting them(I don't see the point of doing this on a car, although it's SOP on aircraft) but it's not possible on sealed bearings.
Re: Front hubs.
« Reply #8 on: 27 July 2020, 19:21:16 »
I think that's why I changed the one I did, although that had more to do with having it replated following an accident repair as I didn't feel the need to give the council any excuses not to replate it rather than because the bearing was actually bad.
I would rustle one up before the next test*, but probably wouldn't fit it unless it fails.
Chances are that it won't fail and you've got another year to deal with it  :y
*presumably Thursday, hence the urgency...
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Front hubs.
« Reply #9 on: 27 July 2020, 19:26:39 »
In all my years of Carlton and Omega ownership, I've never changed a front hub bearing,  :)
Hoof'land storeman.
Re: Front hubs.
« Reply #10 on: 27 July 2020, 20:03:05 »
I had one replaced on my Omega .... I provided an OE bearing & someone else fitted it for me.
Don't ask Nige ....  ::)  ;)
tooleater
Re: Front hubs.
« Reply #11 on: 27 July 2020, 20:57:58 »
I suppose it's just me guys. I bought genuine Vx Mv6 front springs and shocks some years ago, which weren't cheap. 2 years ago Serek fitted new wish bones with poly bushes and a Vx brake discs. As I'm due to visit him this Thursday for a water leak issue, possibly Hbv if I can make it to Huntingdon. I thought while I'm there let's get the Mot advisory for play in NSF bearing sorted. I need to delve deeper on water leak, a litre of water in 10 miles is not good :(
Re: Front hubs.
« Reply #12 on: 27 July 2020, 21:20:15 »
That should be easy to find...
If it is the HBV then it can be made better or worse by setting the climate control on both sides to HI or LO  :y
biggriffin
Re: Front hubs.
« Reply #13 on: 27 July 2020, 21:35:20 »
 Tbh, for the price hbv cost just change it,  big but time my last one turned out to be leaking pipes that went to matrix,not hbv,  Had hbv and by luck the pipes too. ;)
Hoof'land storeman.
  • Chatham, Kent
Re: Front hubs.
« Reply #14 on: 27 July 2020, 21:59:20 »
If it's an advisory, YOU need to check it. There's no point in changing stuff that is working properly.
