Pages: [1] 2 3 4 5 6   Go Down
Author Topic: you might like this  (Read 49481 times)
countrywoman
  • worcestershire
    • skoda yeti
you might like this
« on: 17 August 2020, 16:56:46 »
So using a Omega est as a donner I have been building this 51 Austin, thought you might like a look as we all like photos!!
Smart car axle tube with Astra Watts linkage onto Omega rear hubs . Bit tight , intake will have to sit over top of engine so need some rams horn pipes making .
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: you might like this
« Reply #1 on: 17 August 2020, 18:05:54 »
Pictures need resizing.
Hoof'land storeman.
countrywoman
  • worcestershire
    • skoda yeti
« Reply #2 on: 18 August 2020, 15:00:46 »
yes!!! will see what this computer numpty can do.
« Last Edit: 18 August 2020, 15:06:03 by countrywoman »
    • 530D M Sport, 330i Coupe
« Reply #3 on: 18 August 2020, 15:05:28 »
Interesting project  :y
countrywoman
  • worcestershire
    • skoda yeti
« Reply #4 on: 18 August 2020, 15:08:13 »
Should make a nice ride with abs , air suspension .
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #5 on: 18 August 2020, 15:14:52 »
I do like it.
Have a picture of an X30XE and manual gearbox in an MGB:
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #6 on: 19 August 2020, 14:13:15 »
Can't see many jubilee clips in that engine bay....only 2 in fact..... :D
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
« Reply #7 on: 19 August 2020, 17:10:45 »
Respect to you for doing all that (that some claim us ladies cannot do!!!!! ::) ::) ::) :P :P)
My first car was an 1960 Austin A40, Farina bodied, so I can just imagine what I could have done with that having the Omega parts, and 3.2 engine, available to me today!! ;D ;D ;D ;D
Knowing what condition my A40's chassis was then ( rotted and separated from the body!!) will you have to strengthen it for the Omega engine in addition to the welding I can see you have done all ready? ??? ???
 :y :y
  • Chatham, Kent
« Reply #8 on: 19 August 2020, 17:15:00 »
I didn't assemble it.
Some of those spring clamps have never been off the engine since I bought it.
Every heater hose is attached with Jubilees....
countrywoman
  • worcestershire
    • skoda yeti
« Reply #9 on: 19 August 2020, 19:04:44 »
This is a 1951 Devon so has a separate chassis, the A40 Farina was a rebodied A35 of unitary construction . Old enough to have worked on these when apprentice.
« Reply #10 on: 19 August 2020, 21:21:56 »
That's controversial!  :o  ::)  ;D
  • Chatham, Kent
« Reply #11 on: 19 August 2020, 21:35:09 »
The heater, valve and their plumbing are stock MGB.  One of the engine connections is stock X30. The other is on the new water rail, sized to fit the old hose and placed where we needed it to be. That makes one connection that is 'corrupted' by the Jubilee clamp; the others are correct ;D
countrywoman
  • worcestershire
    • skoda yeti
« Reply #12 on: 20 August 2020, 08:31:50 »
Think I can just get away without moding water rail , just enough room to get a 90 bend  on to clear inner wing. Problem I have is not enough room to fit intake between rad and engine. Only solution I can think is some "rams horn" pipes with intake sat over top of engine .
Lizzie Zoom
  • South
« Reply #13 on: 20 August 2020, 09:53:33 »
Impressive! 8) 8) :y :y
I loved working on my A40, but I had to just to keep it going!! ;D ;D ;D ;D
« Reply #14 on: 20 August 2020, 10:25:23 »
Lose the multirams, no need for ducting between the rad and engine then. You could also consider a 2.5/early 3.0.plenum which is shorter
Pages: [1] 2 3 4 5 6   Go Up
