Pages: 1 2 3 4 5 [6]   Go Down
Author Topic: you might like this  (Read 49523 times)
LC0112G
Re: you might like this
« Reply #75 on: 01 April 2023, 20:05:50 »
Looks great. I don't fancy changing the spark plugs though  >:D
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #76 on: 01 April 2023, 20:23:29 »
Well done, nice to see people’s enthusiasm there’s not a lot of it about these days
Laying a rubber road.
countrywoman
  • worcestershire
    • skoda yeti
« Reply #77 on: 02 April 2023, 12:42:55 »
Will need to take the n/s intake pipe off but its being built so there are silicon hoses joining the bits together. Not sure where the air filter is going yet!!
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
« Reply #78 on: 02 April 2023, 14:31:49 »
Coming along very nicely!! 8) 8) :-* :y
Your hard work is certainly paying off, and that will be one great unique (hot rod??) jalopy :D :D ;)
Santa Pod here you go!! ;D ;D ;D :-*
« Last Edit: 02 April 2023, 14:33:33 by Lizzie Zoom »
countrywoman
  • worcestershire
    • skoda yeti
« Reply #79 on: 02 April 2023, 16:21:48 »
I suppose its a resto rod/street rod, not that its being built to any formula just my own take to make a good daily driver.
« Reply #80 on: 02 April 2023, 17:39:05 »
A big hump/air intake scoop on the bonnet which could house the air filter?  :)
countrywoman
  • worcestershire
    • skoda yeti
« Reply #81 on: 02 April 2023, 17:58:23 »
No its stealth ! there will be room between the "ram horn" bits that go to the intake
« Reply #82 on: 02 April 2023, 18:02:47 »
A Stealth Rod!  Like it!  :y
Lizzie Zoom
  • South
« Reply #83 on: 04 April 2023, 13:18:03 »
Whatever badge may be applied to your creation, it will certainly be fun to drive 8) 8) :y
countrywoman
  • worcestershire
    • skoda yeti
« Reply #84 on: 08 April 2023, 13:06:34 »
All the components have turned up to make the EGR cheat, ordered some prototype board and miniature relay. Bugger pins not on same spacing as holes in board, never mind I can feel some bending happening! Just hope the resistors are correct rating cos its said as example 4K7 and it took that as meaning 47K (not that it looks like you can get one marked up as 4K7).
 Not the first cheat circuit I have made, did one for my lads R1 to bypass the exhaust flap.
addy
  • County Durham.  UK
    • 2.6 CD Saloon 2ltr omega
« Reply #85 on: 08 April 2023, 13:47:10 »
4K7 is 4.7k or 4700 Ohms resistor. Can be found on Ebay
Drives 1995 2.0ltr CD Estate.  2002 2.6 CD saloon
LC0112G
« Reply #86 on: 10 April 2023, 10:14:57 »
No, 47K is not 4K7. 4K7 is 4.7K.
Basically the letters R, K and M are used in place of the decimal point. R indicates ohms, K thousand ohms, and M million (meg) ohms, all followed by a decimal point. So..
4R7 = 4.7 ohms.
47R = 47.0 ohms
470R = 470.0 ohms
4K7 = 4.7 thousand ohms = 4.7K
47K = 47.0 thousand ohms = 47.0K
470K = 470.0 thousand ohms = 470.0 K
4M7 = 4.7 million ohms = 4.7M
Just be thankful you're not dealing with capacitors. 4700pF = 4.7nF = 0.0047uF.
countrywoman
  • worcestershire
    • skoda yeti
« Reply #87 on: 10 April 2023, 14:35:02 »
Never did get into electronics, had one of those build yourself simple circuits kits back in the late 60s and a few even worked!
Pages: 1 2 3 4 5 [6]   Go Up
