Author Topic: Tech2 PCI  (Read 6968 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
Tech2 PCI
« on: 22 August 2020, 16:08:12 »
Currently having a few issues with the board computer massively overcompensating with things like the range and instant mpg, managed to find the correct program code index number to get things working properly again but my Tech2 isn’t allowing me to reprogram anything. Current program code index number is 14 and the one I need to use is 52, any advice on how to get this changed?
It's German but You get the gist.
https://www.opel-infos.de/media/downloads/omega_b_display.pdf
    • 530D M Sport, 330i Coupe
Re: Tech2 PCI
« Reply #1 on: 22 August 2020, 19:08:08 »
Is it a genuine Tech II or a certain USB / Laptop based (the device that cannot be named) Chinese clone? If the latter then don't bother trying to program with that.
P6UL K
  • Dartford, Kent
Re: Tech2 PCI
« Reply #2 on: 22 August 2020, 19:24:38 »
101% Tech2 otherwise I would’ve mentioned the other type of connectivity  :D
Re: Tech2 PCI
« Reply #3 on: 23 August 2020, 19:13:30 »
Which display is yours, early MID, late MID or CART?
P6UL K
  • Dartford, Kent
Re: Tech2 PCI
« Reply #4 on: 23 August 2020, 20:30:51 »
Erm.... 🙈
It’s a colour screen if that helps?
Re: Tech2 PCI
« Reply #5 on: 23 August 2020, 20:32:49 »
CID then ;D
What tyre size are you running?
P6UL K
  • Dartford, Kent
Re: Tech2 PCI
« Reply #6 on: 23 August 2020, 20:37:12 »
CID then ;D
235/45/17 👍🏼
Re: Tech2 PCI
« Reply #7 on: 23 August 2020, 21:16:41 »
Ok, factory standard :y over reading can be caused by smaller tyres, but this rules that out. Any codes in the ABS ecu? Again just to rule out a deeper issue  ;)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: Tech2 PCI
« Reply #8 on: 24 August 2020, 07:43:16 »
I suspect the issue is the same one I had when retrofitting NCDC XXXX and CID. The unit and screen came from a different configuration of car (diesel in my case) so needs reconfiguring to 3.2 spec. Hence the request for code index info.
P6UL K
  • Dartford, Kent
Re: Tech2 PCI
« Reply #9 on: 24 August 2020, 15:12:08 »
All sorted now, looks like I was trying to program the head unit and not the CID! Doh! 🤦🏼‍♂️
On to the next issue!
Re: Tech2 PCI
« Reply #10 on: 24 August 2020, 18:38:45 »
Isn't it CI 074 for a V6 Elite on a CID?
Re: Tech2 PCI
« Reply #11 on: 24 August 2020, 19:52:46 »
Yes 074 rings a bell.
P6UL K
  • Dartford, Kent
Re: Tech2 PCI
« Reply #12 on: 24 August 2020, 20:40:43 »
I worked it out to be 052 going by that list
Re: Tech2 PCI
« Reply #13 on: 24 August 2020, 20:59:35 »
3.0 auto with self levelling and 235/45/17 tyres?
P6UL K
  • Dartford, Kent
Re: Tech2 PCI
« Reply #14 on: 24 August 2020, 21:09:02 »
Correct 👍🏼
