Author Topic: ABS plug at ECU  (Read 5186 times)
steviet
  • glasgow
    • omega cd 2.6 v6
ABS plug at ECU
« on: 22 August 2020, 16:36:11 »
Hi there would anyone have a layout of the multi pin plug off the ABS ecu
Omega 2.6 v6 reg 2002
LC0112G
Re: ABS plug at ECU
« Reply #1 on: 23 August 2020, 00:04:24 »
There appears to be 3 different systems - Standard ABS, ABS + Electronic Stability Program and ABS + Traction control.
Standard ABS is unit K50 at lines 2720-2750 in the circuits.
ABS + ESP is unit K169 at lines 5100-5150 in the circuits.
ABS + TC is unit K95 at lines 4600-4650 in the circuits.
The diagrams give the pin numbers on the unit. Difficult to be more specific unless you know which of the 3 systems you're looking for. If you can work that out I can probably get you a diagram of the plug itself.
A zip of all the circuits here:
https://github.com/MalcolmRobb/OmegaBCircuits/raw/master/OmegaB2002.zip
Or if you want individual pages you can download them from here :
Re: ABS plug at ECU
« Reply #2 on: 23 August 2020, 07:23:49 »
ABS + TC ;)
steviet
  • glasgow
    • omega cd 2.6 v6
Re: ABS plug at ECU
« Reply #3 on: 23 August 2020, 10:20:27 »
Thanks guys for the help
LC0112G
Re: ABS plug at ECU
« Reply #4 on: 23 August 2020, 13:46:28 »
ABS + TC ;)
In which case, it might be this :
Located on the NSF chassis rail, behind the battery.
« Last Edit: 23 August 2020, 13:51:33 by LC0112G »
steviet
  • glasgow
    • omega cd 2.6 v6
Re: ABS plug at ECU
« Reply #5 on: 25 August 2020, 14:56:55 »
Thanks Doctor Gollum exactly what I was looking for  :y
