Author Topic: GPS in Red  (Read 17519 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
GPS in Red
« on: 24 August 2020, 15:18:19 »
My newly acquired f/l elite has an NCDC2013 with colour satnav, but the GPS letters in the top right hand corner of the screen are currently displayed in red.
When I’m trying to access the GPS system on my Tech2 it just displays ‘waiting for data’ and doesn’t seem to connect to anything like it would do if I was programming something else on the car – which makes me wonder if something isn’t connected somewhere?
I’m going to pull the head unit out later in the week to doublecheck that everything is connected on the rear, but any advice on other things to check?
Re: GPS in Red
« Reply #1 on: 24 August 2020, 16:06:48 »
Correct aerial and that it is plugged in. Loom runs across dash to drivers kickpanel, along the door sill trim and up the C pillar. Saloon aerial can be accessed from the brake light trim iirc, estate requires the rear of the headlining to be released enough to access it, (drivers side D pillar trim and rear trim should suffice).  :y
Plugs are:
Back of the cage
Driver kick panel
Estate, roof between c pillar and aerial base.
Saloon, between c pillar and aerial base.
Apart from the cage, the connectors contain gps and phone aerials as well as the radio.
P6UL K
  • Dartford, Kent
Re: GPS in Red
« Reply #2 on: 05 September 2020, 15:16:14 »
Plugs are:
Back of the cage
Driver kick panel
I’ve just managed to find the time and the U-shaped head unit pullers and pulled the head unit out of the dash to check the connections, the GPS connection seems firm enough as does the radio socket and have also checked the connections for the GPS aerial on the roof in the rear and they are still wrapped in the OEM foam to protect them so they obviously haven’t been fiddled with.
Will check any wiring in the drivers kick panel now, have also plugged in the Tech2 and it doesn’t seem to be picking up any thing to do with GPS under the GPS section so not quite sure what is going on
P6UL K
  • Dartford, Kent
Re: GPS in Red
« Reply #3 on: 05 September 2020, 15:27:51 »
LC0112G
Re: GPS in Red
« Reply #4 on: 05 September 2020, 15:51:06 »
Not sure it'll help, but when my satnav packed up it turned out to be a duff crimp connection in the connector between the loom and the antenna in the head lining. The result was an intermittent short between the core and the braid of the coax. The connectors were all still covered in that foam spongey stuff, and hadn't been disturbed since the car left the factory as far as I could see.
The thread is here :http://www.omegaowners.com/forum/index.php?topic=88816.0
It's worth disconnecting the satnav cable in the drivers side footwell and buzz checking between the centre pin and the braid. If it's dead short then the fault is either in the wiring to the antenna or the antenna itself.
Re: GPS in Red
« Reply #5 on: 05 September 2020, 16:56:09 »
The car isn't under cover is it?
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: GPS in Red
« Reply #6 on: 05 September 2020, 17:42:09 »
"I'm actually a Mercedes E Class, honest"
Re: GPS in Red
« Reply #7 on: 05 September 2020, 17:46:47 »
Doofus...  ::)
It won't work indoors/under trees/carports ;)
P6UL K
  • Dartford, Kent
Re: GPS in Red
« Reply #8 on: 05 September 2020, 19:38:20 »
No mate, parked out the front of my house
P6UL K
  • Dartford, Kent
Re: GPS in Red
« Reply #9 on: 08 September 2020, 17:20:01 »
Now fixed! Seems the joint in the drivers footwell behind the kickpanel was loose! Tightened it up and bobs your uncle!  :D
Just need to get it to keep the nav disc in now and not keep ejecting it!
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: GPS in Red
« Reply #10 on: 08 September 2020, 18:05:42 »
Iirc, for testing purposes you should be able to play a music CD in the nav slot to cheeck it works ok.  :-\
My memory is pretty shit though. ::)
P6UL K
  • Dartford, Kent
Re: GPS in Red
« Reply #11 on: 08 September 2020, 18:11:58 »
I’ll give that a go now  :y
P6UL K
  • Dartford, Kent
Re: GPS in Red
« Reply #12 on: 08 September 2020, 18:57:29 »
I can confirm that the nav slot plays music cd’s perfectly  :)
Migv6 le Frog Fan
Re: GPS in Red
« Reply #13 on: 08 September 2020, 19:48:59 »
Good. Just need a good disc then.  :y
Re: GPS in Red
« Reply #14 on: 09 September 2020, 09:21:03 »
Sometimes, polishing the disc may help if music CDs play fine, but very often its a sign the laser is starting to fail.  Sometimes its also due to quite a lot of humidity in the car, esp if it seems to improve after the car has done a few miles and the cabin has circulated air through a bit.
Page created in 0.422 seconds with 20 queries.
