Author Topic: Front wheel bearing /hub change. Question  (Read 3099 times)
Alnico Blue
  • Costa del 'Saffend
    • 2001 2.6 CDX estate
« on: 30 August 2020, 07:29:55 »
hi All      doing a front hub change this morning .  From what I can see, the guide in the maintenance section does not seem to show the actual removal of the old hub after removing necessary brake parts etc. , only "driving" the new one on .  Question is  . . .is a puller required for this , or will it just "tap" off from behind ?  TIA    Al  :y
British made Celestion Alnico Blue = best sounding guitar speaker ever, sadly now made in China
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Front wheel bearing /hub change. Question
« Reply #1 on: 30 August 2020, 09:04:33 »
If it doesn't just slide off, something is badly wrong
    • 530D M Sport, 330i Coupe
« Reply #2 on: 30 August 2020, 09:13:18 »
Once the hub nut is removed it should slide off.
« Reply #3 on: 30 August 2020, 14:04:04 »
Have had to cut the inner race off the stub axle...
Alnico Blue
« Reply #4 on: 30 August 2020, 14:08:32 »
Thanks gents  . . .yep just slid off .       :y :y
Alnico Blue
« Reply #5 on: 30 August 2020, 14:14:11 »
[/highlight]
 crikey  Doc  . . sounds a bit serious  . . . :-\ :-\
This one went really well  . . .  also done wishbone , drop link  and ARB  bush  . . .other side tomorrow other side tomorrow.  Track rod was good so left that .
wish the rear wheels bearings were that easy  ::) ::) ::)
  • Chatham, Kent
« Reply #6 on: 30 August 2020, 14:22:48 »
They're more complicated than is necessary, but there are worse jobs.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #7 on: 31 August 2020, 17:53:36 »
Iirc the front hub nit needs doing up to around 300nm. Hope Alnico is aware of this.  :-\
