How to fix Terry Pagets Vectra...
Started by Doctor Gollum, 04 October 2020, 12:48:14
Standard basic aircon then :y
Try this (presuming fan working as intended)...
https://www.vectra-c.com/forum/showthread.php?200313-Heater-not-getting-hot-just-blowing-cold-air
Glovebox removal is only 4/5 torx screws iirc :y
terry paget
Quote from: Doctor Gollum on 15 October 2020, 17:44:05
Thanks Doc. Having removed the glove box I see a pink lever, but no fag packet black box. Mine seems to lever into a duct. Also it resists pulling off. Any thoughts?
terry paget
There you see a pink lever on the right, but no fag packet size box. l
terry paget
With engine running that pink lever moves when I turn the temperature knob from low to high, so I can imagine it turns a flap inside the vent to divert air flow.
If it's moving then that suggests that it's working :-\
If you pull the centre console trim below the glove box and disconnect the lever and move it manually... Any resistance on it? If yes, then you might be looking at another heater matrix, or at least removing that one to investigate the flap...
Personally, I would pop the trim back in and get it MoTd before spending any more time on it.
Once Motd, you can either tinker to your hearts content or swap it. Mot history suggests that it won't need much, if anything, but it's obviously worth more (financially and to you) with one :y
terry paget
Thanks, Doc.
Quote from: Doctor Gollum on 16 October 2020, 16:32:36
Thanks, Doc. Good advice.
terry paget
MOT passed.
Good news.  8)
You've a year to spend fixing it :y
BazaJT
dave the builder
congratulations on the MOT pass Terry  :)
Quote from: Doctor Gollum on 28 October 2020, 17:54:24
working Heating might be useful THIS WINTER  ;D
Unless you use the VGG screen defrost tool
Kettle of hot water will get you a brand new windscreen.
Diesel till I die
