Author Topic: Brake pad not contacting whole disc face  (Read 8600 times)
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: Brake pad not contacting whole disc face
« Reply #15 on: 12 October 2020, 12:18:08 »
how do they look now ?
grifter
  • Paisley, Scotland
    • Omega 2.6 CD / Elite 3.2
« Reply #16 on: 12 October 2020, 13:05:04 »
I think I can see it is starting to contact the disc more, there is slight sanded look of the outer edges of the bit it wasn't previously contacting, so here's hoping. Other side of disc looks fine, pad was full contact.
« Reply #17 on: 12 October 2020, 13:08:17 »
Sounds like the calipers weren't cleaned properly and/or the outer pad was on the piss :-\
Remove, reclean and refit. Although if the pad is worn unevenly, then you need to replace it ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #18 on: 12 October 2020, 19:36:20 »
I've had pads that are too tight out the box and need a light file to knock the burs or paint off
something is clearly wrong and needs addressing for the un-even pad wear/contact
grifter
  • Paisley, Scotland
« Reply #19 on: 13 October 2020, 12:51:02 »
Pads are not sticking in holder, I've checked twice, they are a nice fit with no sticky bits.
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #20 on: 13 October 2020, 15:16:46 »
As I said previously, it's not unusual for partial surface contact on the disc initially when new pads are fitted, even if the sliding pins are free, the pads are a nice snug fit without being tight, and you are certain the caliper carrier contact points to the hub knuckle are clean and not contaminated. I wouldn't worry about it if you are happy all is well with the fitment - the pad will very soon, if not already, sweep the whole disc face which should then be self evident through the rim.
