Author Topic: Fridge Freezer  (Read 5270 times)
Re: Fridge Freezer
« Reply #15 on: 12 October 2020, 10:03:58 »
Sounds to me like the thermostat has failed. Probably a quick and inexpensive diy fix without the need for the hassle of disposing of the old one. It was when ours failed in the same way.
Yes I thought that was the problem as well and have treated it to a new thermostat, but it didn't cure it.  :(
All installed ok with the thermocouple in the correct location.
It can only be the stat causing it.
What model is it?
Yes I think so, but I think I'll have another look.  Maybe the probe hasn't gone in far enough, although I pushed it in to the mark.  :-\
It's a Hotpoint Iced Diamond RFA52.
Enceladus
  • London
Re: Fridge Freezer
« Reply #16 on: 12 October 2020, 11:27:16 »
Check that the heater element is working. If it isn't then ice builds up and counter intuitively the fridge freezer just keeps running and the ice gets worse.
Re: Fridge Freezer
« Reply #17 on: 12 October 2020, 17:17:23 »
Looks like spot on advice,  :y
The web suggests there is a defrost stat that fails, its attached to the cooling elements behind the panel at the back of the freezer
Re: Fridge Freezer
« Reply #18 on: 12 October 2020, 17:30:43 »
Should have read the OP. :-[
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
Re: Fridge Freezer
« Reply #19 on: 12 October 2020, 18:09:49 »
It’s all in the link I posted :y
Laying a rubber road.
Re: Fridge Freezer
« Reply #20 on: 12 October 2020, 19:41:55 »
Thanks for the link Rae!  :y
Mine's different though, as there's no back panel in the freezer compartment and all the cooling pipes are exposed, forming the shelves that the boxes sit on.  There's nothing resembling a heater element either.  :-\
Re: Fridge Freezer
« Reply #21 on: 12 October 2020, 21:34:02 »
Just checked and its not actually a frost free fridge freezer
