Author Topic: abs  (Read 9660 times)
Re: abs
« Reply #15 on: 21 October 2020, 16:11:15 »
When my front ABS sensor failed the only way to sort it was a second-hand "hub" with the abs sensor in place.... it seems almost impossible to remove the sensor without destroying it.
Re: abs
« Reply #16 on: 21 October 2020, 16:14:47 »
Readily available in the US with a bit of imagination  :-X
jacko
  • london
    • vauxhall omega 2.2
Re: abs
« Reply #17 on: 22 October 2020, 09:13:47 »
okay thanks chaps tec2 it is i think at this point  :y
jacko
  • london
Re: abs
« Reply #18 on: 19 November 2020, 17:17:48 »
HI ALL.
THIS ABS PROBLEM IS BECOMING A TOTAL NIGHTMARE NOW
HAVNT MANAGED TO FIND A GARAGE WITH TEC 2 YET BUT DID HAVE A DIAGNOSTIC DONE AND IT MENTIONS INLET VALVE. AM TOLD ITS NOT WHEEL SENSOR.
SO I HAD THE ABS PUMP CHANGED BUT NOT THE ECU PART EVEN THO IT WAS ATTACHED SWAPPED IT FOR THE ORIANAL ECU AS AM TOLD THAT IT HAS TO BE REPROGRAMEDED IS THIS A
CERTAINTY OR IS IT DOWN TO LUCK.
Re: abs
« Reply #19 on: 19 November 2020, 17:25:30 »
Ideally it needs to be from the same year/engine/gearbox combo.
AIUI there are 3(4) types:
1. Basic ABS. Pre facelift V6 and all other models/years
2. ABS with basic TC. Mid facelift 2.5/3.0
3. ABS with advanced TC. Facelift 2.6/3.2.
(4. ABS with ESP. Euroland Facelift V6 option.)
The mechanical part almost never fails, it's just the ecu part that needs changing/repairing :y
jacko
  • london
Re: abs
« Reply #20 on: 19 November 2020, 17:29:59 »
can you recommend anywhere to repair my abs ecu? :y
amba
  • Medway towns
    • German V6
Re: abs
« Reply #21 on: 19 November 2020, 17:33:24 »
BBA Reman in Rochester,Kent
Address: 1, Stirling Park, Laker Rd, Chatham, Rochester ME1 3QR
Hours:
Closed ⋅ Opens 9AM Fri
Phone: 01634 687222
Re: abs
« Reply #22 on: 19 November 2020, 17:33:29 »
BBA Reman have a pretty decent reputation... Think they're in Kent :y
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: abs
« Reply #23 on: 19 November 2020, 18:02:03 »
BBA are the only company for this job. A superb reputation.  :y
http://www.bba-reman.com/gb/index.aspx
jacko
  • london
Re: abs
« Reply #24 on: 19 November 2020, 18:30:42 »
okay thanks for your help thats the next step then :-\
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: abs
« Reply #25 on: 19 November 2020, 18:31:43 »
And extremely convenient ;)
jacko
  • london
Re: abs
« Reply #26 on: 22 November 2020, 12:57:34 »
hi all.
firstly  thanks for all the info and help.
I am very pleased to say after abs ecu replacement that my problem is sorted.
all works as it should and is now motd for another year.  :) :y
