Help with front suspension
Started by addy, 26 October 2020, 17:29:54
For Spring Cup read Upper Spring Seat... ie the large metal piece that the top mount/ bearing sits in/on :y
The cup washers you describe both have the flat face against the top mount rubber. Should be two fitted... One between the top mount and the shock rod shaft, and one between the top mount and the first nut...
GastronomicKleptomaniac
My left thumbnail still grows in three pieces having smashed the end of my thumb to bits with a badly adjusted spring compressor. 15 years ago... Lesson learnt.
