Author Topic: Facelift fascia buttons sticky  (Read 6867 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« on: 29 October 2020, 07:07:05 »
As title, the surface of the centre panel buttons are sticky, I don’t recall cleaning them with anything strong. Any suggestions as to cause, and cure? :-\
Re: Facelift fascia buttons sticky
« Reply #1 on: 29 October 2020, 09:27:02 »
Rubberised surface reacting with human secretion, dust and UV.
Careful use of Carplan Tar Spot remover or hot water with washing up liquid... All the buttons are removeable (some minor dismantling to get the covers off once removed)  :y
Scrub gently though...
« Reply #2 on: 29 October 2020, 14:43:28 »
Might try the fairy - her blind switch has gone sticky.
Presumably it doesn't peel the coatings off?
« Reply #3 on: 29 October 2020, 15:20:24 »
Not if you take it out and are gentle.
Tar spot remover is effective on stubborn residue.
Ambersil takes a few goes, but again is effective.
Whichever, use only soft, fluffy cloths and go easy. Time and patience is better than force and speed  ;)
Shackeng
  • Ramsbury
« Reply #4 on: 29 October 2020, 18:07:07 »
 :y :y :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #5 on: 29 October 2020, 20:02:15 »
Baby wipes
Hoof'land storeman.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #6 on: 29 October 2020, 20:13:10 »
Baby wipes
As the cause, or the solution?
Using the wrong, or too strong a solution, chemical will quickly soften the coating. I wonder if the current extra use of hand sanitiser(the alcohol is a pretty good solvent) is going to affect this sort of thing.
« Reply #7 on: 29 October 2020, 20:20:51 »
Before it became more expensive than saffron, we used to use hand sanitizer at work as a fast and dirty residue remover...
That said, it was on tedlar coated bulkheads etc rather than soft touch automotive switches  ::)
biggriffin
« Reply #8 on: 30 October 2020, 08:51:20 »
Baby wipes
 To clean the switches,,    they clean anything, and are very neutral.
Hoof'land storeman.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #9 on: 30 October 2020, 11:16:27 »
I use babywipes on all the switches ,trim etc  :y
I keep a pack on the passenger seat, wipe my face when i take my mask off
I add a very diluted BAC50 (Benzalkonium Chloride) solution to the packs of baby wipes
this is the active ingredient in disinfectant  ;)
it's a germicide Algaecide Bactericide Fungicide
Benzalkonium Chloride is also the active ingredient in NHS NON alcohol foaming hand sanitizer
a useful chemical in these current times with Chinese Virus  :P
http://www.kutol.com/wp-content/uploads/wpsc/category_images/formula%20682%20FmHandSanNOAlc_BZK.pdf
https://www.ajicjournal.org/article/S0196-6553(19)30811-9/pdf
Enceladus
  • London
« Reply #10 on: 30 October 2020, 16:06:03 »
How about using Ambersil Amberclens and similar products? That has alcohol in, I believe. Will it make the plastic worse?
« Reply #11 on: 30 October 2020, 16:10:54 »
Their foaming upholstery cleaner is my go to universal cleaner, as per my first second post :y
https://www.halfords.com/motoring/car-cleaning/interior-cleaning/ambersil-groom-upholstery-cleaner-500ml-705152.html
Readily available too...
« Last Edit: 30 October 2020, 16:14:05 by Doctor Gollum »
Shackeng
  • Ramsbury
« Reply #12 on: 30 October 2020, 17:20:18 »
I’m still puzzled that they got so sticky.  :-\
« Reply #13 on: 30 October 2020, 17:54:07 »
It's just something that happens to the soft touch coating that they use on them. Mercedes used a similar substance to coat the light switch bezel on the Barge... not so noticeable on charcoal, but makes beige or grey look positively rank.
If you keep on top of cleaning, once a week in my taxi used to keep them nice, then they stay clean :y
biggriffin
« Reply #14 on: 30 October 2020, 21:15:04 »
  Have you been entertaining ladies from our lords club in your motor sir.
Hoof'land storeman.
Page created in 0.022 seconds with 20 queries.
