Author Topic: windscreen demisting issue - advice please  (Read 4415 times)
Alnico Blue
  • Costa del 'Saffend
    • 2001 2.6 CDX estate
« on: 14 November 2020, 08:08:12 »
There seems to be an issue on my CDX climate control . When trying to keep the screen demisted in these damp and wet conditions , the passenger side seems to work very well. But the drivers side seems very down on "blowing power".  Could it be a pipe has been disloged or not fully located or thinking it may be an issue or fault with the climate control panel itself.
Aircon does not work,  but if that was the issue why is the passenger side  good ?
Betting that any reply will say getting to the pipes/ducts in the dash is gonna be a **** of a job  ::) ::)
Any advice would be great  . . .Thanks Guys    :y :y
« Last Edit: 14 November 2020, 08:12:13 by Alnico Blue »
British made Celestion Alnico Blue = best sounding guitar speaker ever, sadly now made in China
Re: windscreen demisting issue - advice please
« Reply #1 on: 14 November 2020, 09:42:56 »
Is the heat the same both sides?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 14 November 2020, 10:36:17 »
Check scuttle is clear, reset climate panel.
Fix aircon :D
Hoof'land storeman.
Alnico Blue
« Reply #3 on: 14 November 2020, 11:47:10 »
sorry Doc  . . .been out  . . .  gonna check now   :y
Alnico Blue
« Reply #4 on: 14 November 2020, 11:50:08 »
Fix aircon :D
Trev , Re : scuttle clear  . . .do you mean drainage ?   if so clear  . . also no leaves or anything visible on scuttle area .
just going out to check what Doc G has asked .  Back with answers soon  ;)
Alnico Blue
« Reply #5 on: 14 November 2020, 13:28:42 »
Heat is the same both sides .  Tested the "blow" force with just screen on  it seems the same  . .
strange  . . .  what is occuring is the drivers side seems to mist up inside , but passenger side and all other windows are clear  :-\ :-\
« Reply #6 on: 14 November 2020, 15:58:09 »
Pull the drivers carpet. And check for damp/water... Bear in mind that the insulation under it can hold a couple of litres before you feel it on the carpet...
Alnico Blue
« Reply #7 on: 14 November 2020, 17:55:14 »
Checked under the carpets as a first port of call . . . all good .
Using no coolant, so unlikely to be a matrix HBV issue
Possibly just a damp issue from not much use  . . .car sits outside from Mon -Fri.
Just thought it was strange its only the drivers side of screen that is misting . Probably needs a bit of use and may be it will clear better . Might take it for an "Essential Travel " run tomorrow ::)
« Reply #8 on: 14 November 2020, 19:42:45 »
Don't forget to test your eyesight when you get there ;)
Alnico Blue
« Reply #9 on: 14 November 2020, 20:14:56 »
 ;D ;D ;D   thats the one thing I have not checked  Doc ;D ;D ;D   Misty eyes  ;D ;D
    Think me eyes are ok  . . .can still see them big old boats full of containers sailing up the Thames to Tilbury from here at Saffend   and I can still see the sun when its out  . . and thats 93 million miles away  ;D ;D ;D
