Author Topic: Project money pit  (Read 72470 times)
Re: Project money pit
« Reply #15 on: 24 November 2020, 18:00:21 »
If your Omega has foggy windows look for this in driver/passenger side footwell
Cant see from image, but was the black plate holed?  Did you fix the black plate, or just weld over the bulkhead?
My black plate has quite a big hole, but not sure I can get to the edge to weld a plate on, due to where its rusted.  I need to clean it up a bit more to find where the good metal is...   ...or look at other ways of sealing - its only got to last through until probably 6 months.
« Reply #16 on: 24 November 2020, 18:07:18 »
Wire brush it, West System epoxy and woven glass mat/tape, then spray stone chip onto the outside.
Or a foil tray and sikaflex if you cba to do a reasonable job.
« Reply #17 on: 24 November 2020, 18:09:35 »
The fibreglass option was considered, and not yet ruled out. Though same issue, as I think usable metal is out of reach/view
« Reply #18 on: 24 November 2020, 18:19:15 »
Foil and Sikaflex it is then :D
Presumably you have pulled the glovebox? If you need the airbag out of the way, the cover is only held in by a long bolt easily removed once the passenger vent is removed. (the three torx bolts underneath have to be undone to remove the glovebox)  ;)
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
« Reply #19 on: 24 November 2020, 18:23:49 »
New metal plate was welded where the rust was. I had the same problem on my 2.5 v6 but on the driver's side. Rust hole was small, but enough to leak under the insulation foam.
« Reply #20 on: 24 November 2020, 18:30:37 »
On the black plate?
danzigfan
« Reply #21 on: 24 November 2020, 18:35:00 »
I don't do welding so I can't tell you that. I just know that the welder said he never wanted to see me again after welding that tight unreachable spot.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #22 on: 24 November 2020, 18:38:16 »
What is the purpose of the black plate ?
« Reply #23 on: 24 November 2020, 18:43:23 »
It forms part of the bulkhead, but would be in the way when the shell is assembled  ;)
It gets fitted and bonded in after painting
« Reply #24 on: 24 November 2020, 21:35:12 »
I think its all part of the cup that makes the scuttle drain.
« Reply #25 on: 24 November 2020, 22:00:01 »
You wish...
Item #1 it is actually the dash substructure that dictates* right or left hand drive...
http://www.catcar.info/opel/?l=bWFya2E9PVZYfHxzdD09NTB8fG1vZGVsdHlwZT09Vjk0fHxtY29kZT09VlhNfHxsYW5nPT1HQnx8c3RzPT17IjEwIjoiXHUwNDFjXHUwNDNlXHUwNDM0XHUwNDM1XHUwNDNiXHUwNDRjIiwiMjAiOiJWYXV4aGFsbCAgT01FR0EtQiAoIDE5OTQgLSAgMjAwMykiLCIzMCI6IkEgQk9EWSBTSEVMTCBBTkQgUEFORUxTIiwiNDAiOiIgNCBEQVNIIEFORCBTQ1VUVExFIiwiNTAiOiIxLkRBU0ggUEFORUwifXx8c2NvZGU9PUF8fHNzY29kZT09IDR8fG1uY29kZT09MXx8c21uY29kZT09LTd8fGlrZXk9PTg%3D
*the shell also varies as the cabin air intake/engine bay panel is actually part of the shell. That black panel is added during final assembly it's probably what those bolts on the outside of the A pillar (above the upper door hinge) hold in place ;)
Migv6 le Frog Fan
« Reply #26 on: 24 November 2020, 22:25:38 »
Ah, the left / right hand drive part solves the riddle of why its there.  :y
« Reply #27 on: 25 November 2020, 17:00:49 »
You wish...
Hmmm, that could be more than an hour's work ;D
danzigfan
« Reply #28 on: 31 May 2021, 15:53:11 »
It has been a while since I've posted update. She lives, MOT-ed and on the road again after six months :y
danzigfan
« Reply #29 on: 31 May 2021, 15:55:06 »
Pages: 1 [2] 3 4  All   Go Up
