LPG at Shell Forecourts (Autogas)
Started by zirk, 23 November 2020, 16:33:53
YZ250
Quote from: TheBoy on 24 November 2020, 18:29:19
Quote from: Doctor Gollum on 24 November 2020, 18:25:04
LPG is still an actual fuel, so should remain reasonably available if you can store it.
https://www.flogas.co.uk/home/above-ground-tanks
Or http://go-lpg.co.uk/Own_Tank.html
For example...
Most people can't though.  The rules for tanks are quite strict, hence many people in built up areas without access to gas have to heat by electric or oil.
I saw first hand the damage you did with a little gas cylinder ........ imagine the fun you could have with a big tank of the stuff behind your garage.   :o ;D
Quote from: YZ250 on 24 November 2020, 18:41:13
For example...
Nobody in Northamptonshire/Oxfordshire/Buckinghamshire would be safe ;D
Migv6 le Frog Fan
Im nearly 100 miles away, and I think I would lose sleep over it.  ;D
