Author Topic: Poor air flow to the windshield  (Read 2368 times)
Opelduude
  • Norway
    • Omega 2.2 (Y22XE)
« on: 28 November 2020, 18:26:11 »
Every Omega i have owned had this problem with poor air flow onto the windshield.
With the fan on full blast there is just a tiny breeze coming out on the top.
Currently minus 8 degrees here now and i had to let the car idle for 30 minutes before half the window is cleared.
Is there anything easy to check for here?
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Poor air flow to the windshield
« Reply #1 on: 28 November 2020, 18:28:49 »
Does your heater produce lots of HOT air within a couple of minutes of driving? If not a new engine thermostat and heater matrix would be sensible.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 28 November 2020, 18:36:45 »
 First reset the climate control panel. Then check all servos are clicking, then do as nickw says, new thermostat and heater matrix, There's guides for all 3 jobs.
Hoof'land storeman.
Opelduude
  • Norway
    • Omega 2.2 (Y22XE)
« Reply #3 on: 28 November 2020, 18:54:05 »
There is no problem with the heat. The car has normal operating temperature.
The heater matirx and thermostat are replaced 2 years ago.
How do you reset it?
« Reply #4 on: 28 November 2020, 19:05:37 »
It's in the manual and there's a Maintenance Guide for it :y
