Author Topic: Many new parts still remaining  (Read 12027 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« on: 29 November 2020, 13:10:31 »
90540743   Crank sensor                                                   1 BNIB   £50
90566947   Heater bypass valve                                         1 BNIP   £35
93182287   DF4247 Lucas Vented discs                         Pr New £25
90447246 Suspension spacer metal sleeve,                 3   BNIP   £3
90511451   Cam cover seals, AM                                        2   BNIP   £15
90586632   W/S washer pump                                        1   Used   £3
24410986   Servotronic  power steering relay                1   Used   £10
90462823   4 pack door check strap bushes (Yellow)        1   BNIP   £4
Various   Centre Console switchlites for PFL/MFL
Hazard warning, TC (2) Heated seat (2), ECO, Alarm,
Recirc, Heated rear window, Blank.                               10 Used £5
25313359   Fuel Filter AM                                                1   BNIB £10
90491491   Front wishbone bolt                                         4   BNIP   £4
9118135   Induction manifold seals                                6   BNIP   £6
90447244   Rear suspension lower insulator (Washer)        3   BNIP   £1.50
40T1201E4   Door lock repair microswitch                1   New  £2
90324059    Insulator                                                        2   BNIP   £2
90251877   Rear suspension levelling pipe 730mm long        1   BNIP   £12
90473521                            ”                  275mm long       2 BNIP £12
93185493   Lamda sensor Length 570mm + spanner        1   BNIP   £35
90389377   02749 FEBI Ignition switch AM                        1   BNIB £2
90565803   MFL LH headlamp Xenon                                1   Used   £10
90565819   MFL LH Foglamp                                        1   Used   £5
90457820   MFL RH foglamp                                              1 Used £5
9195572   Side Indicator lamps, late type clear glass       Pr   Used   £3
90529188    Timing Belt Roller washer                                4   BNIP   £4
90487795   2.5TD sump gasket                                        1   BNIP   £5
90460437   Front light trim LH                                        1   Used   £3
90460438   Front light trim RH                                        1   Used   £3
9195058
FDB973 Ferodo set of rear pads. Missing 1 slider pin,
and one back plate spring                                                 1 New   £5
        Omega Handbrake gaiter green AM                 1 New   £5
       Bose Disc cassette                                                 1 Used £5
   Assorted new nuts, bolts and fixings for Omega         POA
All items are genuine GM unless marked with make or After Market (AM).
Above prices exclude Postage.
BNIP/B = Brand New In Pack/Box
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Many new parts still remaining
« Reply #1 on: 29 November 2020, 20:05:50 »
 If I still had an Omega, I would ask you for a price for Everything. Can't understand why somebody hasn't... :-\ :-\ :-X
Hoof'land storeman.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #2 on: 29 November 2020, 20:11:46 »
Agreed. There are lots of hoarders here who could cherish all that for longer than they own Omegas ;D
iansoutham
  • SE London
    • Omega 2.0 m/f/l est CDX
« Reply #3 on: 30 November 2020, 07:43:06 »
Am interested in check strap bushes and the switches please.
Will have to sort out payment, etc this evening as at work on phone at the moment.
Can you PM payment details and total posted and I will send address for posting.
Thanks
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #4 on: 30 November 2020, 14:34:15 »
I'm all 'hoarded out'....three sheds full and three car boot loads.....I am done!  ::)
Shackeng
  • Ramsbury
« Reply #5 on: 30 November 2020, 18:02:46 »
I am surprised myself, mostly new parts, inc HBV & crank sensor!
  • Chatham, Kent
« Reply #6 on: 30 November 2020, 18:05:09 »
The reason is simple: you listed them about 15 years too early.
Shackeng
  • Ramsbury
« Reply #7 on: 30 November 2020, 19:05:02 »
Probably true, but I won’t be around then. :(
And some of these are already as rare as the proverbial!
LC0112G
« Reply #8 on: 01 December 2020, 14:59:36 »
Suspect I'm in need of the Crank sensor.  >:(
I can do Cheque, Paypal or Bank transfer - What do you fancy?
Cheers
Malcolm
Shackeng
  • Ramsbury
« Reply #9 on: 01 December 2020, 16:32:22 »
Sorry Malc, sold today.
« Reply #10 on: 09 December 2020, 22:26:47 »
Could I please purchase the LH front fog lamp?
I had a slight mishap with a small deer at about 60mph..... amazingly, all I need is a foglamp and a number plate!
Shackeng
  • Ramsbury
« Reply #11 on: 10 December 2020, 07:21:36 »
Certainly James, PM me your details.
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #12 on: 21 February 2021, 13:47:51 »
Hi. Do you still have a pair of clear side indicators please ?
cam.in.head
  • West yorkshire
« Reply #13 on: 08 March 2021, 17:32:55 »
have the clear indicators s sold  please ?
Shackeng
  • Ramsbury
« Reply #14 on: 08 March 2021, 19:15:43 »
Sorry I missed your earlier one. Yes still available.
