Author Topic: Crank sensor...I think?  (Read 33682 times)
LC0112G
Re: Crank sensor...I think?
« Reply #45 on: 15 December 2020, 20:32:49 »
Well, I promised some pictures. Story is...
I started the car in the garage seeing if it would stall. It didn't, but it wasn't running right. I popped the bonnet, and started waggling connectors and wires down the back of the Plenium, where the crank sensor connector lives. I then became aware of a hissing sound - like a vacuum air leak. I couldn't immediately locate it, but it was coming from here somewhere...
Then after a bit more poking I saw it...
And removed from the car...
The "funny" thing is I'd been aware for a while that the brakes were a but 'wooden' for the first few seconds after a cold start, and I was intending to replace all the pads last weekend. Now the reason is obvious - poor vacuum to the servo.
I think it probably explains the stalling too. It's not too little fuel/blocked fuel filter/low fuel pressure - it's too much air. The ECU won't be able to meter the air getting in through the hole , so it'll run very lean.
The hole was made by the pipe rubbing on the Air Con quick release connector. It's obviously not happened 'suddenly' and worn away over the years until eventually it rubbed through. It actually seals quite well on the A/C connector.
Anyway - haven't got a spare pipe, so a bodge fix required...
Several layers of glue filled heat shrink. Not very neat, but getting the lengths of heat shrink over the coupling nut and around the elbow is a bit of a game.
Has it cured it? - Dunno yet I managed to break one of the vacuum pipe couplings by the one way valve getting the wretched thing off, so need to fix that first. But I'm optimistic.
« Last Edit: 15 December 2020, 20:35:00 by LC0112G »
B52
  • Glasgow
  • 02 MV6
« Reply #46 on: 16 December 2020, 04:34:14 »
Well, wouldn't have thought of that - my money was on something electronic.
Good detective work there.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #47 on: 16 December 2020, 07:34:24 »
Well done Malc. Something to check for others.  :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #48 on: 16 December 2020, 08:32:00 »
That would certainly explain your problem :y
It's very common on VAG cars, where the fix is to cut out the holed pipe and join it with vacuum hose. And to ensure it no longer rubs on whatever caused the hole....
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« Reply #49 on: 16 December 2020, 14:53:54 »
Interesting case. Checked immediately mine but perhaps due to right side traffic slightly different design and there is a plastic clip to prevent those hoses to touch, too.
« Reply #50 on: 16 December 2020, 15:03:43 »
Uk cars left the factory with the same spacer clips ;)
Actually quite rare to find them still present, even on the best kept cars...
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #51 on: 16 December 2020, 16:35:06 »
I think mine still has them. Will try and remember to check tomorrow.  :)
    • Grandland 1.5 diesel
« Reply #52 on: 16 December 2020, 16:38:02 »
They look like one of those "Where the fick did that bit come from?" items that get chucked after a repair job.
Diesel till I die
  • Chatham, Kent
« Reply #53 on: 16 December 2020, 16:49:52 »
More like a "It doesn't do anything, and it takes too long to get back under there, fit it in the bin" parts, that six months later makes you do another 3 hour job figuring out why the damn car doesn't work properly.
« Reply #54 on: 16 December 2020, 16:51:03 »
I've always had the odd screw or bolt left, I'm still alive  ;D
Diesel till I die
LC0112G
« Reply #55 on: 16 December 2020, 17:01:29 »
But you've got a screw loose. ;D
« Reply #56 on: 16 December 2020, 17:14:52 »
But I'm still upright and breathing, which is all that's required  :)
Diesel till I die
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« Reply #57 on: 10 August 2023, 20:08:45 »
Just checked mine as got me paranoid and spacer still there, fitted a little before the other picture and looks like never been touched  :), but I have had car from new  ;D
I'll go and read her a story and tuck her blanket in  ;D
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
« Reply #58 on: 13 August 2023, 18:23:55 »
Indeed! :y :y
I have now checked mine and all is ok.  Those pictures certainly gave me a scare, like my loose plenum servo pipe!! ::) ::) ;)
Pages: 1 2 3 [4]  All   Go Up
