slap piston in swap x30xe?
Started by olm, 13 December 2020, 15:26:47
Quote from: olm on 14 December 2020, 16:08:49
Quote from: Doctor Gollum on 14 December 2020, 15:41:14
Actually, remove the cams from the 3.0 and, if they are good, ie not scored up or otherwise damaged, fit them to the 2.6. It will pep it up a bit.  :y
Return to 2.6 don't contemplate. If I take out the engine it will be for something bigger.
Well, you could fit an LS but you can kiss goodbye to about £12-15k.
If it's your daily driver, a working 2.6 is better than a dead or unavailable larger lump. Thems about your options...
olm
Quote from: Doctor Gollum on 14 December 2020, 16:29:36
If I don't have a LS  it's because the laws don't allow it  ;D
The engine will hold, it takes a few thousand miles and what's left
Not if it's knocking it won't...  :D
dave the builder
Quote from: Doctor Gollum on 14 December 2020, 18:48:21
the Omega radiogram goes up quite loud  ;)
well mine does ,often  :D
cam.in.head
if it is only piston slap then it could last for years but piston slap / wear doesnt normally manifest itself as metal filings in the sump ?
olm
Quote from: cam.in.head on 14 December 2020, 19:16:50
They are tiny particles, it is logical after a grab, but yes, it can work like that for a long, long time, in fact the noise disappears soon and already works smooth and quiet
olm
#36
It been calling a long time, if it were crank bearing it would have broken up long ago
Presumably this is the same really well kept engine that never had a cambelt change since leaving the factory?
olm
Quote from: Doctor Gollum on 14 December 2020, 20:35:04
You are supposing wrong
Quote from: olm on 15 December 2020, 08:58:38
I was being slightly sarcastic.
Is the engine that you went to change the belt on only to find that it was almost destroyed? Presumably you bought the locking tools before you fitted the new belt?
olm
Quote from: Doctor Gollum on 15 December 2020, 11:26:22
No, it squeaked and looking at the belt it was almost destroyed. Then I put on a new belt and the noise persisted, it turned out to be the covers, I put those of 2.6 and it was solved. I don't know why, but that's how it was
