Pages: 1 2 3 4 5 6 7 [8] 9 10   Go Down
Author Topic: 17 year old Corsa C won't start.  (Read 45002 times)
    • Grandland 1.5 diesel
Re: 17 year old Corsa C won't start.
« Reply #105 on: 06 January 2021, 18:07:00 »
I imagine the RAC have been out ,looked, told him to take it to a garage to be fixed
i doubt RAC would fit a fuel pump IF that is the issue
Yes, Dave, we know that  :P
Diesel till I die
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #106 on: 06 January 2021, 18:11:49 »
maybe they can get the mower going instead  ;D
« Reply #107 on: 06 January 2021, 18:13:04 »
I'll bet he's dreading the jaaaaag coming out of warranty.
Diesel till I die
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #108 on: 06 January 2021, 18:18:52 »
He won't bother with the Jag once he's got a new motorbike to nip down to Barnsley on  ;D
he's probably knobbled the Corsa so Mrs Opti can't follow him  :P
« Reply #109 on: 06 January 2021, 18:42:07 »
Very helpful man from the RAC has been and tells me the crank sensor is fine. :y
He removed the rear seat and there was a lot of banging for twenty minutes or so before he declared.....it's 100% your fuel pump that is the problem.
Easy fix apparently. Ten minute job.
Right then how much for a new/ or used fuel pump? :y
« Reply #110 on: 06 January 2021, 18:42:56 »
I pay £105 each month.
« Reply #111 on: 06 January 2021, 18:50:42 »
I can't be assed to look, but how many times during this thread has the fuel pump been mentioned?  ::)  :P  ;D
Did you get him to look at the mower as well? ???  :)
« Reply #112 on: 06 January 2021, 18:55:33 »
You'll find out when you buy it.
Diesel till I die
« Reply #113 on: 06 January 2021, 19:00:14 »
I have fixed the mower which now runs like a swiss watch. :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #114 on: 06 January 2021, 19:02:55 »
none to buy on your favourite site youtube  :P but loads on ebay  ::)
depends if you fit just the pump £16.05 delivered patent part clicky
or
used genuine complete assembly clicky £25
or about £200 from vauxhall
« Last Edit: 06 January 2021, 19:11:17 by dave the builder »
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #115 on: 06 January 2021, 19:14:57 »
or
Usually, the tricky part is loosening the retaining ring.
« Reply #116 on: 06 January 2021, 19:15:30 »
Yeah, I'll bet it does  ;D
Diesel till I die
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #117 on: 06 January 2021, 19:26:13 »
Gas axe ,he don't want to grow old anyway  ;)
« Reply #118 on: 06 January 2021, 19:34:04 »
or
Thanks Dave.
Presumably all I need is the metal pump which is hidden beneath all the plastic crap.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #119 on: 06 January 2021, 19:50:36 »
or
Thanks Dave.
if you opt for just the pump you will need to take apart the swirl pot assembly to swap the pump, this will need some fuel line clips/clamps to be replaced and you run the risk of damaging things during this process .
a used /working complete one may be easier for someone of "limited skill"  :-X Not that i'm pointing fingers  ;D :D
Pages: 1 2 3 4 5 6 7 [8] 9 10   Go Up
