Pages: 1 2 3 4 5 [6] 7 8 9 10   Go Down
Author Topic: 17 year old Corsa C won't start.  (Read 45058 times)
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: 17 year old Corsa C won't start.
« Reply #75 on: 31 December 2020, 19:03:14 »
No I’m asking are you getting a spark from the plugs that is the first place to look
I'll need to lift the coil pack to reach the plugs unless I'm doing something wrong.
On that Corsa there is ample slack at the connector end to allow the coil pack to be laid on its side to test a random spark plug or two that you have kicking about.  :y
« Reply #76 on: 31 December 2020, 19:05:34 »
A quick Google and it looks like the fuel pump is under the back seat. Do I simply pull the rubber hose off then turn over the engine and see if it spurts petrol?
This is how I checked to see with old 'carb cars' when the fuel pump was under the bonnet.
« Last Edit: 31 December 2020, 19:07:32 by Field Marshal Dr. Opti »
« Reply #77 on: 31 December 2020, 19:10:12 »
.....and before anyone asks. I know to lift the coil pack rather than prise it off with a hammer and a screwdriver. :)
you remove the 2 torx that clamp it down and fit/screw in bigger (m8 thread i think) bolts and lift up on those ,so it comes out evenly
takes longer to get the tool box out than pull the coil pack
no point in guessing, or asking here what other people's guess is
just go check the pump(can you hear it ?) , fuel at the rail ? and plugs  ;)
no lightning when cranking = no worky  ;D
No . Not when I switch the ignition on. Silence.
    • Grandland 1.5 diesel
« Reply #78 on: 31 December 2020, 19:12:36 »
Far too technical for Worzel.
Diesel till I die
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #79 on: 31 December 2020, 19:13:04 »
there's a valve (like on a tyre/wheel) with a black cap on , on the fuel rail
or there are 2 sticky out things on the sides of your head ,called "ears" that you can use to "listen" if the pump is  running with the key in position 2
fuel pump relay is the same as Omega ,purple IIRC
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #80 on: 31 December 2020, 19:16:18 »
OK
if you can't hear the fuel pump with key on accessory then just bypass the relay and listen  :y
pretty sure it primes on the z12xep on key on
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #81 on: 31 December 2020, 19:24:05 »
It's easier to disconnect on of the hoses at the engine end. Or you could use the valve intended for the purpose.....
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #82 on: 31 December 2020, 19:27:29 »
relay purple bottom right ? may be yellow
2 fat terminals are 12V to the pump  :y
the 2 thin terminals are for the coil of the relay ,DON'T short those  ::)
info here linky
« Last Edit: 31 December 2020, 19:39:23 by dave the builder »
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #83 on: 31 December 2020, 19:40:50 »
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #84 on: 31 December 2020, 19:48:12 »
Get your colleague to listen by the pump to see if it is making a noise while you crank to engine. But.. if you simply pull the plugs you will see if they are wet if they are it’s obviously getting fuel. Whilst it’s dismantled you can then simply check for a spark at the plugs. If you have fuel and spark then it is most probably a mechanical problem
Laying a rubber road.
« Reply #85 on: 31 December 2020, 22:39:17 »
I fear this thread is getting a little technical for poor old Lord Opti!  :-\
« Reply #86 on: 01 January 2021, 06:20:06 »
Yes, give the old lad a bit of a headache. Never mind, new year, new car.  :y
Diesel till I die
« Reply #87 on: 01 January 2021, 11:29:14 »
Our thoughts should really be with the long suffering Mrs Opti!  :)
He'd better get it going soon though as he'll be starting a Which New Laptop? thread otherwise...  ;D
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #88 on: 01 January 2021, 11:36:57 »
New Year , new car don't be such a tight arse..😃😃😃
« Reply #89 on: 01 January 2021, 13:24:20 »
I'd have been tempted by your old Merc.
Pages: 1 2 3 4 5 [6] 7 8 9 10   Go Up
