Author Topic: NCDC "no magazine"  (Read 6455 times)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
NCDC "no magazine"
« on: 04 January 2021, 21:45:46 »
Really wanted to play my new copy of Dark side of the moon on the way to work today. Ejected the CD magazine, put the disc in and reinserted it.
The Magazine kept popping back out, as though whatever retains it has broken. Sometimes it will stay in, but the display still says "No magazine".
Is it fixable ?
Tia.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: NCDC "no magazine"
« Reply #1 on: 04 January 2021, 23:36:10 »
Does it stay in with no Discs in the Mag. ?
Also if you really need to you can play a CD on the top single Disc Slot, you select it using the CD/CDC toggle button, obviously you won't be able to use Sat Nav whist in this mode, but guessing you should know the way Home by now.  ;D.        ........or maybe not.  :-X
« Last Edit: 04 January 2021, 23:39:07 by zirk »
Migv6 le Frog Fan
« Reply #2 on: 05 January 2021, 00:21:54 »
Havent tried it without discs in the Mag. Will give it a try in the morning. I forgot thst the satnav disc slot could be used for music CD,s.
Doesnt it damage the laser though ?
Migv6 le Frog Fan
« Reply #3 on: 05 January 2021, 18:05:09 »
Ok, so the magazine stays in its slot with no discs in it, but the display still says "No Magazine".  ???
I have a spare 2013 GID in the shed. Might have to swap some bits over. Problem is, its so easy to pull the front off when pulling the unit out of the dash.  ::)
    • Grandland 1.5 diesel
« Reply #4 on: 05 January 2021, 18:12:04 »
Just use the satnav slot, it's easier.
Diesel till I die
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #5 on: 05 January 2021, 18:56:18 »
The front is always coming of mine just shove it back on mun.
Laying a rubber road.
Migv6 le Frog Fan
« Reply #6 on: 05 January 2021, 19:05:44 »
I have been using the Satnav slot, but the brand new I put in thereCD skips a bit sometimes, I have a feeling it might damage the laser, and I really dont like things in the car not working as intended.  ;)
Migv6 le Frog Fan
« Reply #7 on: 05 January 2021, 19:51:54 »
Just tried the Mag in the changer again without discs and it wouldnt stay in. Kept popping out again.  ::)
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #8 on: 05 January 2021, 20:01:21 »
mine has done this once !
i tried to work out what latches it in place and found there was a little metal lever / stub that needed flicking back to the left i beleive. from what i can remember it is somewhere to the right of centre ,quite near the back looking into the opening. sorry hard to describe but you should see what i mean .
this worked on mine. may not be your problem but you never know
Migv6 le Frog Fan
« Reply #9 on: 05 January 2021, 20:38:50 »
That sounds helpful, thanks. Will take a look.  :y
« Reply #10 on: 05 January 2021, 20:40:12 »
Swap the CDC3 part over with your spare one from another NCDC....    ...but you must also change the vertical board in the CDC section.
Migv6 le Frog Fan
« Reply #11 on: 05 January 2021, 23:42:43 »
Sounds like the sort of thing I could make a right old mess of.  :y :D
