Y32SE cold start low revs
Started by 456lbft, 06 January 2021, 09:19:50
456lbft
All good points and well made.  In my experience, which is mainly mucking about with Lotus Carltons over the past 25 years, the more effective the calipers (and the bigger the diameter the discs are) the less you notice the softness of the pedal, because you have to use less pedal effort for a given amount of retardation.  In the same way that one can bleed the brakes and get a good pedal only for it to feel spongy once the engine is running and the servo kicks in. The feel of a Lotus brakes after we've upgraded to 6piston front calipers is miles better than the already good 4 pot ones, because of the hydraulic advantage of smaller pistons and greater pad area. The only car I've had that has had a really firm pedal is my own Lotus Carlton track car, which has braided hoses throughout and (crucially in my opinion) no ABS pump.  Also I am always struck by the sharpness of the brakes on more or less any new car, for instance a delivery mileage courtesy car offered by a dealer or a shiny new hire car usually takes me by surprise the first time I hit the brakes until muscle memory is recalibrated.  So I am sure that the accumulated wear of every component has a cumulative effect over the years.  I've also been told that the lining of rubber brake flexis can break down over time and contribute to the mushiness by trapping micro bubbles of air, so that even changing to new rubber flexis can be an improvement, never mind the teflon lined braided hoses that can be obtained.  I've often wondered what method is used at the factory for bleeding brakes, because even with the fanciest pressure bleeding system, it still seems to takes ages and lots of fluid to get all the air out of a complete brake (and clutch) system.
Carlton 3.6 Track Car
Omega 3.2 MV6 Fred
Actually, that's a slight mistake on my part...
Monaro 5.7 CV8 calipers are a bolt on four piston upgrade retaining the Omega v6 discs. And fit 16" wheels. No mods required.
The VXR Monaro calipers require 330x32 discs so are greater diameter AND thickness. And fit 17" wheels. Calipers bolt on but may require tweaking depending on disc choice. I used Merc ML ones machined for correct hub centre fitting and spacers on the carrier to correct for disc offset. Also Monaro hoses as longer than Omega ones. This is what I fitted to mine.
The dogs danglies are the AP set up from the Monaro, 360x36mm iirc but the discs are stupidly expensive. And you need a custom bell to allow direct fitting to the Omega hub. Calipers should bolt on but there are variations. The standard single piece Monaro discs technically fit, but are just as expensive and the bolt pcd is 120 not 110. Require minimum 18" wheels.
The difference is in a guide iirc.
Carlton options might be bolt on but you'll have to experiment. If you can get the parts.
VXR8 brakes don't fit as the caliper mount dimensions are different.
johnnydog
Sounds a lot of expense and faffing about to gain what in particular? Unless you are the habit of driving like those 'ne'er do wells' on those Police Camera Action type programs, or absolutely cane the brakes with your style of driving, in my opinion, Omega brakes are more than adequate.
Migv6 le Frog Fan
Am I correct in thinking Monaro calipers use the same pads as an Omega ?
Quote from: johnnydog on 08 January 2021, 20:04:46
Exactly. Making them work as designed is hardly difficult or expensive either.
I've said this before, but if you are going to modify brakes it is only worth doing if you go straight to the biggest ones you can fit under the wheels. Changing calipers on a standard size disc is a complete waste of effort and money.
cam.in.head
and gm decided through great expense that the weight of the car ,etc,required the brakes it fitted.
always a personal choice but standard every time for me .same goes for silly exhausts too !
plus finding an insurance company that accepts modified cars .
Migv6 le Frog Fan
Im not sure I would agree. The Omega is a big heavy car, and Im pretty sure if it were being designed today it would have to have a much improved braking system. They were ok ish when it was made, but things move on and Omega brakes arent great by modern standards.
Quote from: Migv6 le Frog Fan on 08 January 2021, 20:36:07
Nope :D the calipers are PBR and use a derivative of Corvette pads ;)
Quote from: Nick W on 08 January 2021, 20:54:19
The base Monaro calipers are a two piston caliper with a longer pad contact than the Omega ones and about a third more piston area. The VXR ones are similar to the base ones but with a greater pad area to allow for the larger discs and calipers  ;)
Before uprating to the Monaro VXR set up, i used to get brake fade between Horsham and Crawley... Fast dual carriageway with five roundabouts in as many miles.
No point having a 3.0/3.2 Omega if you don't use it :D
I believe that Pauls fitted the base Monaro calipers to his 3.2 with good results.  8)
cam.in.head
I've always found the standard brakes to be powerful enough and I drive a lot of new cars as well. Sure they may need more of a push ( less servo feel) but  certainly pull the car up quickly if needs be.
Everyone to their own .
Quote from: cam.in.head on 09 January 2021, 09:55:04
After driving Fords and other over-servoed cars for many years, the progressive Omega pedal was a nice surprise. I prefer non-servo brakes, but they're only really feasible on lightweight cars ;D
It's not that the Omega brakes are inadequate, it's just that they don't always inspire confidence and that's in part because the fundamentals of the Omega brake set up was fifteen years old when they started building them. There's a reason that Plod pads were a different spec to factory and retail ones and why they all got the bigger discs from '98 ;)
Also, fitting bigger calipers/discs does nothing to improve pedal feel, but they do inspire confidence in that they will pull the car up faster and more consistently time after time.
A well sorted Omega is a genuine pleasure to drive hard, and upgrading the brakes allows you to to make the most of it.
456lbft
I agree for road use, but I intend to use the car on track too where the full performance can be enjoyed without risk to my license and/or other road users.  As I am now closer to 60 than 50, my preference on the road these days is wafting not racing...but it's nice to have some extra reserve for when a LHD lorry wanders into my path on a motorway.
Omega 3.2 MV6 Fred
456lbft
Quote from: Migv6 le Frog Fan on 08 January 2021, 23:17:50
Also true :y
Omega 3.2 MV6 Fred
456lbft
Back on Topic!  The MV6 has started every time this last week, even when left outside on the coldest -3deg nights.  I'm used to it now only ticking over at 800rpm with no drama compared with the higher cold start revs of the Lotus Carltons I am more used to, which I realise is probably due to the requirement of getting cats (which are halfway down the car) warm for emissions requirements.  The swift warming of the engine and heated cloth Recaros are also most welcome on my short drive to work. ;D
Omega 3.2 MV6 Fred
