Author Topic: How do I remove this bastard?  (Read 5941 times)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: How do I remove this bastard?
« Reply #15 on: 09 January 2021, 17:32:31 »
The sender plugs into the underside of the cap and exots out of thee top in the flat black connector  ;)
I know how it's meant to be  :y
oh I see ,it's the black plug far right of the pic ,
i thought someone had run a separate 2 cores/wires direct to the sender, bypassing  the 4 pin plug ,routed into the gasket instead , my bad
« Reply #16 on: 09 January 2021, 17:34:04 »
I think there are 2 multiplugs side by side on the underside of the 'lid'
Two wires going to each. The two wires that are stripped are connected to the basket.
I am financially 'robust' so don't need to be doing this, but like to fix things where and when I can. Perhaps I'm just weird. :) :) ;)
The work shy scouser wouldn't bother. :)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #17 on: 09 January 2021, 17:36:31 »
It's much easier to steal a complete running car than dick about fixing one  ;)
« Reply #18 on: 09 January 2021, 17:47:22 »
Yep.....That is the scouser philosophy. ;D
« Reply #19 on: 09 January 2021, 18:48:21 »
It looks like there's a single tab top and centre of the sender 'unit'... It isn't clear as the camera is looking straight down at it... Hold this towards the centre of the swirl pot and the sender should simply slide up ;)
Access into the rank to see what's what isn't great, but at least you aren't trying to do it from underneath  ;)
