Author Topic: Before I buy....  (Read 17520 times)
Before I buy....
« on: 10 January 2021, 13:19:32 »
This looks identical to the fuel pump I have removed from the car, but the advert states Corsa B rather than Corsa C. Is the same pump used for both cars?.....I have offered £10 which the seller has accepted including P and P.
https://www.ebay.co.uk/itm/Fuel-Pump-fits-VAUXHALL-CORSA-B-In-tank-1-0-1-2-1-4-1-6-FPUK-815037-9120218-New/264993296769?_
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Before I buy....
« Reply #1 on: 10 January 2021, 15:19:10 »
you've enjoyed the job so much that you want to buy the cheapest, non branded pump ,from a seller based in China .
I hope it turns up quickly  ,so you can fit the first pump of many  :y
« Reply #2 on: 10 January 2021, 15:39:47 »
I'm thinking of selling the mighty Corsa.
No need to spend more than necessary.
Unaware it may come from the land of the slitty eye though.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #3 on: 10 January 2021, 16:18:20 »
OK  ;D
scroll to the bottom of the listing .....
Business seller information
OUTONG AUTO SPARE PARTS.,LTD
ruibiao dai
Dai Ancestral Temple Baoyi Tang xia
325204 Wenzhou
China
though it does have a UK VAT number showing  :y
shipping "Economy Delivery (Other Courier 5 days)"  should mean it's drop shipped from a UK warehouse
Item location:   Walsall, United Kingdom
sometimes Ebay sellers tell fibs  :o
it states "delivery On or before Mon. 18 Jan" though ,so there's that in your favour  ::)
you could of had one delivered and fitted by now ,had you used my original links on another thread and had it listed,
possibly even sold to some spotty ,unsuspecting teenager by now
don't forget to show the buyer where you "welded" the scuttle ,fitting the battery  :P
    • Grandland 1.5 diesel
« Reply #4 on: 10 January 2021, 16:36:18 »
Would you buy a used car from this man?  ;D
Diesel till I die
« Reply #5 on: 10 January 2021, 16:36:49 »
You can have it for a couple of grand, Dave.
Just needs an MOT. :y
The women will be all over you. ;)
« Reply #6 on: 10 January 2021, 16:37:56 »
That line doesn't quite work when it comes from a scouser. ;D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #7 on: 10 January 2021, 16:54:45 »
2000 Gambian Dalasi I assume you mean ,which is about £28.50
OK you need to deduct £56 form the £28.50 for the MOT
which means you would owe me £27.50 (if i decided not to haggle ,which I always do when buying a car)
Hardly a selling point  ???
I have women all over me as it is   ::)
wanting jobs doing
« Reply #8 on: 10 January 2021, 17:13:27 »
Don't be such a tight bastard.
You're a builder.......you charge £2000 to clip a bit of loose guttering into place. :) ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #9 on: 10 January 2021, 17:45:02 »
Tight yes ,but my birth certificate clearly states in the name of father section "some soldiers"  :P
guttering is important, if it leaks ,water can wash away ground around the foundation.
subsequent underpinning and making good, redecoration etc can cost tens of thousands  ;)
therefore, my repair skills justify the reasonable charges  ::)
It's not cheap buying a ladder ,rusty van and calling yourself a builder you know  :D
« Reply #10 on: 10 January 2021, 19:10:39 »
Seriously though.......a good builder or DIYer can be worth his weight in gold.
I added 3 complete bathrooms to another house. Sorted out the the flow of the water and it's escape route. The only thing I paid for was a qualified electrician.
Anything I can do myself I will do myself. :y
« Reply #11 on: 10 January 2021, 19:13:53 »
It's not cheap buying a ladder ,rusty Omega and calling yourself a builder you know  :D
Are you sure?  :D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #12 on: 10 January 2021, 19:26:01 »
Are you sure?  :D
I'll let you know when i've saved up enough pocket money to buy a ladder  :P
Great  :y
though I do make used to make  ::) a fair bit fixing DIY and failed attempts  :P
« Reply #13 on: 10 January 2021, 19:27:12 »
How much to decorate stairs and landing? Asking for a friend...  ::)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #14 on: 10 January 2021, 19:37:53 »
How much to decorate stairs and landing? long is a piece of string ? Asking for a friend...  ::)
****sucks through teeth and sparks rolly fag back up ****
prepped, painted, wallpapering
bag of sand plus
(£1000+ in victim talk)  ;D
a good decorator won't be using B&Q DIY quality paint etc and if you supply it ,he'll charge you more to use it  ;)
if you have the time and skills then DIY  :y
