Author Topic: ECU  (Read 3385 times)
WHITE OMEGA
  • Damascus-Syria
    • Opel Omega 2.2 2002
ECU
« on: 13 January 2021, 20:01:38 »
DEAR ALL
Which is the correct ECU model for X30XE AUTOMATIC ?? is it the HH or the AF
what the letters stands for?
thanks
Re: ECU
« Reply #1 on: 13 January 2021, 21:13:36 »
The letters are production batch codes.
Any 2.5/3.0 ecu will work provided the matched transponder and key chip for the new ecu is used.
The gearbox has a separate ecu so is irrelevant for the purposes of your question.
Re: ECU
« Reply #2 on: 17 January 2021, 15:52:52 »
The 2 digit letters are called Ident Codes, as signify differences.
The differences can be varied, including:
Functional differences
Programming differences
Internal differences that are generally unnoticeable
Physical differences (such as different connectors, or different protocols for communications)
