Pages: [1] 2 3 4 5 6 7   Go Down
Author Topic: Interior light  (Read 49665 times)
gbh
  • forest of dean
    • omega cdx 2.6
Interior light
« on: 15 January 2021, 14:41:05 »
The alarm went off and it would seem that the interior map light is not dimming and going off.It does go off when ignition is turned but back on again after and staying on so could be a timer fault or any other suggestions to overcome this problem would be most welcome.Is there a relay?
Re: Interior light
« Reply #1 on: 15 January 2021, 15:27:25 »
Push the headlight switch in and report back ;)
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: Interior light
« Reply #2 on: 15 January 2021, 15:38:32 »
deja- vu is kicking in !
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Interior light
« Reply #3 on: 15 January 2021, 15:41:24 »
At least it was well lit ;D
cam.in.head
  • West yorkshire
Re: Interior light
« Reply #4 on: 15 January 2021, 15:41:38 »
if its accompanied by strange sounds from the warning buzzer too i can tell you what happened on mine too !
gbh
  • forest of dean
    • omega cdx 2.6
Re: Interior light
« Reply #5 on: 16 January 2021, 00:12:25 »
Well some good news and bad,I reconnected the battery after being off for a day and the interior light was off and appears for the moment to be behaving.I'm sure it will reoccur again but for now ok i did hear a slight whining noise for 20 seconds or so but a little unsure what that was.Thanks for now and a safe new year to all members
cam.in.head
  • West yorkshire
Re: Interior light
« Reply #6 on: 16 January 2021, 13:04:18 »
That wining noise was probably coming from the warning buzzer like mine did. It cleared itself for a day or two but then reappeared again .
Not saying it's the same identical fault but if you can find my post and read through it you may have the same symptoms/ fault.
My interior light wasn't going off properly,warning buzzer was sounding but muted,quieter if you put on the parking lights or even with the key in ignition and doors shut.
It turned out to be a common blue wire that connects the central locking,warning buzzer ,door aperture switch,and also goes across into the drivers door .mine was this wire that went into the door.it was low to earth and fooling the central locking ecu to turn the interior light on ( or not turn it off !) I unplugged the door connector and it cleared. There was some water in the door connector but even after drying it with a hairdryer the wire was still low so earth so I disconnected it. Everything is working so its either something unimportant,something I've not noticed yet or something that my car doesnt have  fitted.
Next time I take door panel off il see where it goes
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: Interior light
« Reply #7 on: 16 January 2021, 14:02:14 »
Could that be the heating/aircon vents behind the dash resetting themselves? Always had that on my CDX Desmond. Perhaps a more informed OOFer can confirm or say that i'm talking horlicks.  ;D Which is highly probable.  :D
gbh
  • forest of dean
    • omega cdx 2.6
Re: Interior light
« Reply #8 on: 16 January 2021, 15:12:14 »
And there back on again!!!!
gbh
  • forest of dean
    • omega cdx 2.6
Re: Interior light
« Reply #9 on: 16 January 2021, 16:55:22 »
Pulled it out and in several times with no difference
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
Re: Interior light
« Reply #10 on: 16 January 2021, 17:44:26 »
Take the fuse out and put a torch in the pouch, that’s what I did ;D
Laying a rubber road.
ronnyd
Re: Interior light
« Reply #11 on: 16 January 2021, 17:59:56 »
Are you a kangaroo Rae? :)
gbh
  • forest of dean
    • omega cdx 2.6
Re: Interior light
« Reply #12 on: 16 January 2021, 19:38:21 »
Well of course I could take the bulbs out but would be nice to test and sort out
Re: Interior light
« Reply #13 on: 16 January 2021, 19:43:10 »
Door contact switches next then ;)
  • Chatham, Kent
Re: Interior light
« Reply #14 on: 16 January 2021, 19:54:25 »
Which includes an thorough inspection of the wiring around them
Pages: [1] 2 3 4 5 6 7   Go Up
Page created in 0.033 seconds with 20 queries.
