Pages: 1 2 [3]  All   Go Down
Author Topic: Nipples!!!!!  (Read 36051 times)
Re: Nipples!!!!!
« Reply #30 on: 27 January 2021, 13:06:17 »
Back in the day I new a lad who owned a Marcos. Pretty sure he said it came with a 3 litre Volvo lump rather than  the Essex V6 lump from Ford.
Looked great but Nick will probably think it's a bag of shit. :D ;D
Must have been an early one to have a Volvo. Really early Marcos had plywood chassis, which was an interesting idea. I like them, but the front end styling isn't quite right; the nose is too long and high, with a bodyline that dips as it runs backwards. Still better resolved than an E-type though.
From memory I think it was a 1969 car on a 'G' plate.
A real 'bird puller'..... :y
Re: Nipples!!!!!
« Reply #31 on: 27 January 2021, 13:11:03 »
So you don't think the E-Type or Marcos are design icons. Give me an example of a car Mr W would consider attractive.
Austin Metro?.... ::) ::) ::) ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Nipples!!!!!
« Reply #32 on: 27 January 2021, 14:05:12 »
I've no doubt the E-type is a design icon. I just find it ugly, especially in convertible form. I think the XJS is much better looking, although that would have been better with the rear axle line moved further back. Jaguar were toning down their trademark flashiness by then, and the cars are better for it - the series 1 XJ6 in a subdued colour is a car I could look at for hours.
I like the Marcos a lot but, as I said, think the nose isn't quite right.
I'm quite happy to criticise styling, but you should consider that I can't draw. At all! Any car I sketch ends up looking like a cartoon of a Lego Transit, an would be best stuck on a fridge with magnets ;D
Re: Nipples!!!!!
« Reply #33 on: 27 January 2021, 15:14:28 »
The E-Type is good but not flawless. It looks best in side profile, but the screen is too upright.
 Viewed from the front the track is way too narrow. I would say this is where the Jaguar design team got it wrong the most.
Beauty is obviously subjective but I think the Alfa 1750 GTV coupe and BMW 3.0CSL get it more right than wrong.
  • Chatham, Kent
Re: Nipples!!!!!
« Reply #34 on: 27 January 2021, 15:43:39 »
Lots of sixties cars had narrow tracks, but E-type is probably the worst.
The silencers and exhaust tips are ghastly.
Sills are too far from the ground, and radius under the car too much. Fixing that would have allowed for a deeper door, which would look better and be easier to get in,
front and rear valances match the sills, and angle upwards too steeply.
Bumpers are too high.
Headlight bowls don't match any of the lines of the front of the car.
The coupe has a good silhouette, but the convertible looks like it had the roof hacked off with a straight cut and a windscreen plonked on at random. I think that most cars that were available in both bodystyles look better as a coupe
Re: Nipples!!!!!
« Reply #35 on: 27 January 2021, 18:45:38 »
Fookin ell, Nick. :D
Sir William will be turning in his grave.
Re: Nipples!!!!!
« Reply #36 on: 27 January 2021, 23:14:11 »
I think he wore out his bearings when they launched the S type and the diseasel, front wheel drive Mondaguar. ;D
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: Nipples!!!!!
« Reply #37 on: 27 January 2021, 23:57:15 »
 ;D ;D :y
  • Chatham, Kent
Re: Nipples!!!!!
« Reply #38 on: 29 January 2021, 20:39:52 »
Back to the subject:
on the left, the guilty culprit: a crusty calliper with damaged bleed threads and seat, plus piston and seals of dubious durability
on the right: £66 worth of brand new calliper. Note it comes with a cap for the nipple.
20 minutes later it was on the car, bled and handbrake working.  I then finally found my trimtape to stick the on the new front number and ran the car around the block. All is good, although it will need a few more miles to for the pads to relearn how to sweep the whole disc surface :y
Pages: 1 2 [3]  All   Go Up
