Author Topic: Misfire/EML light  (Read 8452 times)
New POD
  • Miseryside
    • NEED MV6
Re: Misfire/EML light
« Reply #15 on: 29 January 2021, 14:34:35 »
Plug 6 is generally the one that gets missed ::)
A toasted bannock says that the sponge on the firewall is completely soaked and dripping onto the coil pack plug...
My 3.2 had a misfire this evening. It's been pissingbrain for days. . No engine management light, but when I put the code reader misfire on cylinder 6.
It was okay later, after 5 miles of running, but i reckon it's water on the coil pack or the plug hole full of oily mayo.
When it stops raining I shall investigate.
It stopped raining.  The more often I take the plugs put the easier it gets each time. I've had the car for 60k and I've had the coil packs off at least 8 times.
The cam cover gasket was done by me, about 50k ago.
The fault appears to be either:
have been the spring that sits at the end of the coil pack and wraps around the spark plug had come off the coil pack.
Damp.
A small amount of FOD in the plug well.  (The remains of an oily rubber glove Which was probably me)
I swapped the spring for the one on plug 2, and swapped spark plugs 4 and 6. Thus if I get a misfire from 2, it's the spring, and 4 it's the plug.
Cleaned the plug well with erm cleaner and a cloth.
Put it all back together, deleted the fault code and went for a drive..
Seems fixed.
B52
  • Glasgow
  • 02 MV6
« Reply #16 on: 31 January 2021, 00:46:51 »
Thanks - I've acquired a 2-4-6 coil pack just in case but I'm mindful it might be something similar (not least because the plugs have been replaced recently and it's No 2 cylinder when No 6 would be the prime suspect).
Find out next week.
B52
  • Glasgow
  • 02 MV6
« Reply #17 on: 22 February 2021, 15:01:45 »
Solved: faulty coil pack replaced
