Author Topic: temp sensor outside  (Read 5238 times)
john1959
  • birmingham
    • omega 3.2 elite black
temp sensor outside
« on: 31 January 2021, 16:37:40 »
hi gents had bit of a cold few nites recently.cars temp outside showing silly numbers 66c etc now itsFCdeg any ideas whats up with it?cheers
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: temp sensor outside
« Reply #1 on: 31 January 2021, 17:30:29 »
On my 3.2 I'm sure it was the outside temperature sensor fitted in the front bumper. If you open the bonnet you can see it fixed in its holder behind the front bumper. I replaced mine and if I recall it wasn't much money to replace. Check the wiring to it first though.  :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #2 on: 31 January 2021, 17:44:22 »
Yes, the outside temperature sensor is fitted to the front bumper central , inside, shares a loom with the fog lights .
there is a plug to the N/S under the headlamp area that that loom plugs in.
could just be a bad connection
or new sensor about £7
« Reply #3 on: 31 January 2021, 18:21:04 »
If only TBE's was the sensor, but looks to be loom :(
« Reply #4 on: 31 January 2021, 18:29:02 »
Easy enough to dig out and repair ;)
Replacing is a different issue as finding an unscabby used one could be problematic. Notwithstanding that you're dumping the car at some point...
    • Grandland 1.5 diesel
« Reply #5 on: 31 January 2021, 18:31:06 »
Are they not the same as the ones in, say, an astra?
Diesel till I die
« Reply #6 on: 31 January 2021, 18:44:58 »
The sensor is :)
« Reply #7 on: 31 January 2021, 18:48:51 »
If its in the bumper loom, it would be trivial to repair I reckon.  Once the bumper is off, obviously.  Don't like removing that bumper unless absolutely necessary, as it had seen too much action before I got it, and I then did a bloody good job of melting it.  And then she has idiotted on a high kerb.
And as you rightly point out, I suspect it will never get driven in my ownership again.
« Reply #8 on: 31 January 2021, 18:58:42 »
There's unlikely to be much holding the loom in, and unplugging it is easy enough from underneath, even with the chavtastic bumper :D
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #9 on: 31 January 2021, 21:20:12 »
As the car is now at the patch it up for another year stage, cut the sensor wires back to where you can reach them without removing the bumper, and attach the new sensor somewhere more convenient. Use Sikaflex, Araldite, cable ties, lockwire, speedtape, whatever you have.
« Reply #10 on: 01 February 2021, 17:00:39 »
As said, I reckon its done its penultimate trip now...
grifter
  • Paisley, Scotland
    • Omega 2.6 CD / Elite 3.2
« Reply #11 on: 02 February 2021, 13:50:53 »
Part No: 9152245
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
« Reply #12 on: 08 February 2021, 14:07:48 »
And in SAAB's too
Jan Suhr
Stockholm, Sweden
www.protouring.se
