Author Topic: laminate flooring trim  (Read 12449 times)
Re: laminate flooring trim
« Reply #45 on: 13 February 2021, 12:29:59 »
This is the type of scribe mitre I was referring to Andy. ...
 :y :y I'm sure I'll be able to do something better than they did  :y
« Reply #46 on: 13 February 2021, 12:33:33 »
It would be a struggle to worsen it :D
It looks like the were relying on the boatd spacing to avoid cutting in the hearth :-\
If they had started with a half board, they would have gotten the front edge and a chunk of the sides spot on.
    • Grandland 1.5 diesel
« Reply #47 on: 13 February 2021, 13:00:06 »
And, of course, you will post up some pics so that we can pass comment learn from your mistakes see how it should be done  :y
Diesel till I die
« Reply #48 on: 13 February 2021, 13:16:57 »
;D ;D ;D
« Reply #49 on: 13 February 2021, 13:55:24 »
My late FIL was an accomplished DIY enthusiast. His work was simply flawless.
He used to say a good amateur is  as good as a professional provided he thinks it through and takes his time.
Obviously this sentiment doesn't apply to brain and open heart surgery. ;)
We, at OOF, have faith in your ability, Mr Beanz. :y
« Last Edit: 13 February 2021, 13:59:53 by Field Marshal Dr. Opti »
« Reply #50 on: 13 February 2021, 14:45:22 »
 8) 8)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #51 on: 13 February 2021, 15:02:35 »
An amateur has more time to do a good or excellent job.
A good professional knows when and what is good enough. Anyone who doesn't make visible pieces fit properly cannot be considered 'good'.
« Reply #52 on: 13 February 2021, 15:05:13 »
Sums it up really. .....plus they tend to care more.
My sister needed a new fence because a gap at the end meant her mutt could escape. A builder was engaged and the four foot gap became a two foot gap.......still more than large enough for her sinewy pooch to make it's bid for freedom.
His solution to the problem........."stick some chicken wire in the hole, darlin".... ;D
She was not pleased. ::)
« Last Edit: 13 February 2021, 15:11:07 by Field Marshal Dr. Opti »
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #53 on: 13 February 2021, 15:24:57 »
Bloody Builders  ::)
had you just wrapped the dog in chicken wire ,you wouldn't have needed a new fence  :D
Pages: 1 2 3 [4]  All   Go Up
