Vauxhall Carlton "scrapped"
Started by dave the builder, 18 February 2021, 17:03:37
I appreciate that it still has to be legally roadworthy, so speed taped sills and rear valences are asking to get an appointment with a magistrate ;D
Making Bosch jetronic work after a 20 year rest is more of a concern. In which case the MoT exemption is a moot point as a modern drive train counts as a substantial change and therefore requires an MoT.
Quote from: Nick W on 20 February 2021, 17:04:40
Quote from: Field Marshal Dr. Opti on 20 February 2021, 16:54:24
Reminds me of my 1976 (P) 2500S. Mimosa yellow with Stag alloys as standard. Twin SU carbs instead of injection.
Overdrive made it very 'long of leg' although economy was still woeful at around 13 MPG, following a play with the Colourtune.
how the hell do you get it that low? Single SUs are excellent, but I've never seen a decent throttle linkage on a factory twin(or more) installation.
Colourtunes are pretty good but if using them on multiple carb engines, you want at least one per carb. I've a friend who tunes the quad Dellortos on his hotrod with eight of them, bought for pennies at various autojumbles.
The only way I could get it to run smoothly, and with immediate throttle response, was to have it running 'rich'
Set up to run properly on the Colourtune it would always gag and stutter as though it was starved of fuel and running too 'lean'
It's possible the carb needles and jets were worn and needed replacing. I was only 23 what did I know? :)
Lovely looking car though.
Quote from: Field Marshal Dr. Opti on 20 February 2021, 17:29:17
Probably just needed a spot of oil in the dampers in the carburettor pistons. ;)
Raeturbo
Of the correct viscosity of course :y
Laying a rubber road.
Quote from: Raeturbo on 20 February 2021, 18:04:46
The last drips out of the engine oil can always worked for me.
cam.in.head
Always works for me too still. 20w/50 although the reccommended stormberg oil is much thinner but with modern fuel its not going to be the same characteristics anyway in terms of throttle response.
Raeturbo
Straight 20w or (3 in 1 machine oil) was recommended for engines in normal tune although I doubt if many of us knew or cared then ;D
Quote from: Raeturbo on 21 February 2021, 18:40:12
Are you sure that 3in1 is 20w?? If you put 3in1, hydraulic oil, sewing machine oil or any other similarly thin oil in a dashpot it won't be there for long.
Raeturbo
Positive, I said 3 in 1 machine oil :y
Raeturbo
dave the builder
Raeturbo
 Now you're talking Dai :y I'll make a Welshman of you yet ;D I've a bottle of the matured in Madeira here now.... think I'll have a swig👍
Oooh a bulk store of sheep dip :D
just in time for Lambing ;D
Raeturbo
Hey Dr, give it a try. The sheep love it, so can't see why you won't  :y
