Never assume anything
Started by STEMO, 23 February 2021, 13:06:08
Puncture fixed(a puny little panel pin that really should have bent rather than punctured) and a quick dive into Halfords for a can of tyre weld......just in case.
Diesel till I die
countrywoman
My Skoda Yeti has no spare and no place to put one, can of glop they give you wouldn't go in even with valve removed . Well you cant squeze a plastic bottle against a tyre and there was no jack either to take load off . Taken to a can of get you home stuff and a better tyre pump.
Rangie
Both our cars have spare wheels fortunately, but the Range Rover is a space saver I've actually got a matching full size alloy but I need to see if it will fit into the cradle, not keen on this new idea of no spare wheel.
Quote from: STEMO on 24 February 2021, 15:36:04
One of my tyres on the Mondeo is starting to leak from the rim again.  ::)
So I might chuck a can of goo in there, see how that goes...  :-\
Quote from: Rangie on 25 February 2021, 10:28:18
My ML has a space saver too .... I doubt the 265/20 wheels would go anywhere near the spare wheel well. The R Class before it had a spare, but one that was 'flat'  ;) (never needed to use it so didn't need to worry about whether it'd go back into the wheel well)
https://www.youtube.com/watch?v=JQuJZSRC4WQ
Quote from: Andy B on 25 February 2021, 11:25:55
It's not uncommon to find that a full-size wheel doesn't fit in the boot: TTs and Beetles, XC90s come with a bag because the wheel doesn't fit the cradle(and the factory bodykit/twin exhaust takes up that space ::) ), some Porsche 911s have the spacesaver behind the passenger seat, etc
Quote from: Nick W on 25 February 2021, 11:32:21
I never like the idea of an under slung spare that's exposed to the elements. It's bad enough having to maul with a dirty horrible wheel from the car without having to crawl under it to retrieve a wet muddy spare.
Quote from: Andy B on 25 February 2021, 11:36:58
I saw far too many where the mechanism had seized. Even more common was wheels that were so rusty the tyre wouldn't hold air. Few car owners check the spare when it's in the boot; they never do it when it's under the car. Fitting the spare in a cradle under the car uses the same space as putting it in the boot where it should be, it's just the other side of the floor.
Quote from: Nick W on 25 February 2021, 11:44:55
That's exactly what I thought too!  :y
And more secure in the boot too. There was a modified hanger for the Kia my Dad used to have to help prevent people crawling underneath & cropping the cable to nick the spare.
Migv6 le Frog Fan
Thats one more problem with the stupid French contraption. An absolute pita to get to the spare.
Quote from: Migv6 le Frog Fan on 25 February 2021, 13:27:02
Try a Megane estate; there's a sticker with pictograms that 'explain' how the mechanism works. They were drawn by someone who had never seen the mechanism. Or a car. Or a wheel. Then they were prettied up by a graphic designer who clearly thought they'd been hired to draw Manga.
I can sense a narrative building up here from Albs, in that he really wants to get rid of the French POS and use the Omega as his daily drive.  ::)
The money you are saving in not going to the supermarket should be spent so you can waft along to work in Vauxhall's best effort at luxurious comfort!  :y
Rangie
I checked mine when I first bought it 18 months ago it all worked okay + I lubricated the whole mechanism, I need 4 new tyres in the next couple of weeks anyway so will have the best of the old ones put on the alloy, I have seen full size spares slung under the RR Sports but maybe a different size cradle , may be an option to change it if required.
Picked up the new space saver this morning, £72 with the VAT. Took it to the tyre place along with my old one with tyre on. Went and got Krispy Kreme donuts. Came back, handed over donuts in exchange for wheel, job jobbed.
Diesel till I die
Its got a cradle? so 2002-2009 model year?
The more recent ones have internal storage and when its a space sever there are blocks that you can remove so a full size will fit.
The parts shows only one cradle option (although the armoured one is different)
