Author Topic: Fault gets a bit worse  (Read 5908 times)
gavlar001
  • kent
    • omega 2.6 mv6
« on: 23 February 2021, 18:21:26 »
Hi everybody thanks for replies on the dimmer question.Driving along today on a short trip and the internal front inside light is stuck permantly on
Then the engine managment light comes on and stays on.Code reader shows 1 code P0304.Felt like i had lost a bit of power as well.had to remove light so as not to run down battery.Any ideas thanks gavin
    • 530D M Sport, 330i Coupe
Re: Fault gets a bit worse
« Reply #1 on: 23 February 2021, 18:29:49 »
0304 is Cylinder 4 missfire
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #2 on: 23 February 2021, 18:30:58 »
cant see them being connected thou.
gavlar001
  • kent
    • omega 2.6 mv6
« Reply #3 on: 23 February 2021, 18:37:43 »
Had a bit of Mayo on oil cap other day just thought it was because its cold.
cam.in.head
  • West yorkshire
« Reply #4 on: 23 February 2021, 18:41:54 »
have mayo on the cap permanently . on mine thats because over the last 5 years ive only done a 3 mile journey to work once a week in it and the occasional drive out on a weekend. it will only be in the top end of the neck where the condensation rises to
gavlar001
  • kent
    • omega 2.6 mv6
« Reply #5 on: 23 February 2021, 18:58:07 »
Yep thanks thats what i thought.Opened the main fuse box and its a white relay shaped thing thats making all the buzzing noise as well as constantly tripping.
cam.in.head
  • West yorkshire
« Reply #6 on: 23 February 2021, 19:17:45 »
tripping ?
gavlar001
  • kent
    • omega 2.6 mv6
« Reply #7 on: 23 February 2021, 19:19:29 »
Sorry its just buzzing sounds like its clicking over and over.Its a white relay in the main fuse box under the steering wheel.
cam.in.head
  • West yorkshire
« Reply #8 on: 23 February 2021, 19:32:38 »
yes thats it.( the lights on warning buzzer) its not that thats faulty  just a consequence of the fault. you could unplug it if you want until you sort out the fault .
i assume it makes the noise but quieter than if you actually open the door with lights on ?.then it comes on as normal .
also noise varies with dimmer switch position and key position.
on mine it did flatten the battery overnight but then it could be a different fault ?  ?
quite a few people have had this issue recently and like mr gollum says probably a combination of damp weather and not using car much especially as with the lockdown.
gavlar001
  • kent
    • omega 2.6 mv6
« Reply #9 on: 23 February 2021, 19:50:46 »
Thanks mate.Its gotta be water coming in from the door thats shorting something.Was worried it might be the start of a head gasket failure.Tommorrow im off so im gonna take a good look at it.I will take the door card off see if its wet inside there.Will take off plenuim and remove spark packs and then remove spark plugs and check for oil.Also check the coolant etc.A P304 could i suppose be caused by water ingress into the packs if somethings not right i suppose.As for the interior light being stuck on i dont know.
cam.in.head
  • West yorkshire
« Reply #10 on: 23 February 2021, 20:10:24 »
if you have a meter just trace your way back . i started at the warning buzzer socket on the 31 pin.this is the blue wire i mentioned.
it actually goes all the way across the car under the carpets and terminates about 6" above the big connector blocks behind the passenger kick panel .it joins to several other blue wires.
 i cut the joint and found just 1 low to earth wire. traced it back to the drivers door connector.ive left mine unconnected and its fine. that blue wire is now clear to earth but its still unconnected .
if you look in your door check its the blue wire issue first to save unnesessary work.im curious where it goes to ??
as for the missfire you should find something. damp or water in the plugwell(idealy) or maybee oil ( less ideal !) and possibly some cracking insulation on the coilpack. this can be cleaned up/ dried out and epoxy sealed if nesessary if its not too bad and worth trying first before a new one . water can be dried up,plug cleaned externally and either find the cause of scuttle leak or add an extra rubber mat between engine top and scuttle foam as well .
gavlar001
  • kent
    • omega 2.6 mv6
« Reply #11 on: 23 February 2021, 20:29:37 »
Thanks mate, didnt know that buzzer was in the fuse box.Ive got tech2 on computer somewhere so will look at the wiring diagrams for that.How do i find a short to earth.Will keep you posted as to what the score is  :y
cam.in.head
  • West yorkshire
« Reply #12 on: 23 February 2021, 20:37:53 »
you need a multimeter set to ohms. probably wont pick anything up unitil you go into the 2k scale but it was enough to fool the ecu. .definately shouldnt get a reading on basic 200ohm scale .
test between body and the blue wire .or( the 31 terminal socket where the buzzer plugs into. / or the lightswitch if you have removed that ?) same wire ! same number ( 31 b i think was its full marking but 31 anyway !)
youl be ok .
oh and test it with the doors shut or it will be zero anyway !
gavlar001
  • kent
    • omega 2.6 mv6
« Reply #13 on: 23 February 2021, 20:45:04 »
Thanks, i take it im looking for a reading of an amount of ohms on the meter.
gavlar001
  • kent
    • omega 2.6 mv6
« Reply #14 on: 23 February 2021, 20:52:39 »
Thinking about it it had a towbar on it which i didnt need so i removed it and the wiring was behind the plastic panel in the boot.I taped them off but maybe theyve got wet.Will have to check that as well.
Page created in 0.028 seconds with 20 queries.
